Thread: Order of adjustments to pool chemistry
    Jul 2016
    Boca Raton, FL
    10
    I have often read that you should not add two chemicals to your pool at once, so I am wondering if there is a proper order of operations for adjusting pool chemistry?
    I think I read about this in one of the Pool School articles, but I cannot seem to find it.
    For example, if my PH is out of balance and my Free Chlorine is too low, which should I adjust first? Should I wait a day between adjusting one and adjusting the other?
    Thanks.
    12,500 cubic foot pool
    in ground
    gunnite / Diamond Brite
    About 30 years old?
    Pool from City water
    Aug 2014
    Northern IL
    4,615
    Re: Order of adjustments to pool chemistry
    Most chemicals can be added at the same time. The exception is when using muriatic acid (MA) and liquid chlorine/bleach. You should wait at least a half an hour between those additions as together they can create dangerous fumes. If pH is significantly out of balance, or you are preparing for a slam, do that add first. Otherwise, do FC first.
    domct203's Avatar
    Jun 2015
    CT
    3,588
    As mentioned, chlorine and muriatic acid should never be added, nor stored together. The fumes created are very toxic.
    I usually wait 30 minutes with the pump running between any chemical additions, and when adding items that do not dissipate, like calcium or CYA, I will add half of the amount I need, retest in 30 minutes then add the remainder needed.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
