Thread: Need Help With Design. Breaking Ground Soon.
    Jun 2014
    Cream Ridge NJ
    30
    Attached is the design offered by my landscape architect. You can see that I have 1140sqf + 86sqf for spa = 1226sqft. The math that I am seeing to calculate the formula is not adding up to what I am being quoted. My math is coming in way higher, but pools I have seen similar size are saying they are using much less than my estimate. I got an estimate from one gunite supplier and seems about 25cuft on the high side.
    Obviously I do not want to under order because that can be a nightmare for a job, but I also don't want overage to go to waste either. I will stress no rebound and everything shot solid and I will be breaking ground in 60 days.
    One last point. Where you see jumping rocks, will be another waterfall so I will need to gunite under their to prevent leakage.
    Nov 2015
    Carrollton tx
    451
    Re: Need Help With Design. Breaking Ground Soon.
    cu ft of what ?
    Concrete ?
    Doug - Purchased 1/2016, 1995 house with 16x31 ft, ~23000 gallon Gunite pool w 11x7 spa, 3 Pentair VS pumps, a boost pump for polaris 3900 and a BaduŽ Jet super-sport swim jet pump, 1.5 hp blower, a CL460 Cartridge filter. TF-100 test kit. Aquapure SWG, iAqualink - Lots to learn. New Aquabright, Jandy LEDs, CMP LED Sheers.
    kellyfair's Avatar
    Jun 2016
    Tampa, FL
    926
    Sounds like he's asking how much gunite will be used.
    Does one have to order the gunite by the cubic foot, or does the gunite company take care of that and just charge for what was used? I've never seen anyone else ask for this info...
    16' by 4' Intex Ultra Frame AGP
    Intex 120V Krystal Clear Sand Filter Pump & Saltwater System CG-28679 with E.C.O.
    Hayward Through Wall Skimmer, Intex Auto Cleaner - works great!
    TF100 Kit and Speedstir
    Get the Pool School ebook, free on Google Play!
    Jul 2016
    Oviedo, FL
    13
    Not only that, I would think the designer should have the proper calculation available through the program based on an assumed thickness. It's too complex a shape to be able to estimate by hand. Are you handling the GC work yourself? Is this the only thing you are giving a gunite contractor?
    IG Plaster 11948 gal pool; Pentair FNS Plus FNSP-48
    Century Centurion Pump - looks like 1 HP?
    TF-100 Test Kit
    Spa w/ overflow to pool
    Jun 2014
    Cream Ridge NJ
    30
    Yes, I have a rough estimate based on my calculations of about 75-80 cu yards based on a pool 40 x 20 that used 60 cu yards. I called a guy in North Jersey and he was at 120 cu ft and I am like thats impossible. He was charging a premium and over estimating.
    I would say this, forget the cuts. 45 x 25 with average depth of 6ft. The thickness will be 8" Another gunite supplier is talking in only sq ft. I am finding calculators that only offer partial information.
    I know I am missing something. It cant be that difficult.
