Thread: It's that time.
    Marty D's Avatar
    Jun 2016
    Quogue new york
    146
    It's that time.
    Can anyone tell me what cover to get for our inground pool? It will have to be custom made. I did some looking and seems the price can be in the $4k. I want a cover that will last for many years. We live in the north east. I was told to get a mesh cover due to all the leaves and snow up here. Thanks
    Inground 30x60 vinyl W/2 French ends w/sitting spa. Built 2007. 2016 pentair electric 140 heat pump. Pentair VS-SVRS pump. System 3 modular filter SM series S7m120
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    Re: It's that time.
    Loop-loc- see details in this thread: Best Winter Cover - Cold Climate
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,805
    Re: It's that time.
    I have a Merlin and would highly recommend Merlin Smart-Mesh - same 15 year prorated warranty as L-L. Merlin would say they are better Loop-Loc and vice-versa. It's a very viable option at least. Pricing may be my similar but is set by each dealer so you could get it cheaper from one or the other. Specific features related to how they deal with raised areas (if you have any) may be a differentiator. All of the hardware between the two look identical and the cover for that matter.
    We've been through three winters, several blizzards, with no issues. Water level maintenance is critical. If you spring a leak in your liner over the winter and have a heavy snow your cover could break and will not be warranted - same with either.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Marty D's Avatar
    Jun 2016
    Quogue new york
    146
    Re: It's that time.
    I heard of that name. What should I get , Smart mesh or solid with two drains? I'm getting a 50-50 on both. My pool guy said soild and the company that's makes the cover said smart mesh. The company you used only makes smart mesh. My pool guy said he doesn't like smart mesh because it lets Uv light in and water gets green when you open pool.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,805
    It's that time.
    I have SmartMesh. I've never opened to a green pool in 4 years (crystal clear in fact - never even cloudy). But opening before the water temp reaches 60 degrees is also of paramount importance (and closing after it drops below 60 degrees too). Merlin claims it blocks 100% of UV rays. I can't say but I've had good results.
    Our SmartMesh cover is heavy enough, I certainly would never get a solid cover since we've had perfect results with this and I can manage it by myself.
    Marty D's Avatar
    Jun 2016
    Quogue new york
    146
    Re: It's that time.
    Thanks for the info. I don't know why my pool guy said not to get smart mesh because I read that the new covers do not let uv in. The older covers did. I'm getting prices now. It's about $4500 smart mesh and they will close the pool also. Hope to get 10 years
