Thread: Need advice on setup
    Sep 2016
    Hnl/hi
    1
    Hi, we just got a place with supposedly a new pool and setup although I doubt the motor is less than a year old as they claim. It very load and I'm questioning the size of the pipes. Can anyone tell from these pictures? Also what is the round device on the top of the poll on the right?
    thanks,
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Need advice on setup
    This equipment does look to be at least a few years old, I am not sure what your question is otherwise.
    setsailsoon's Avatar
    Oct 2015
    Stuart/FL
    467
    Pipes look to be standard size for your equipment. Hard to tell age from photos... ask for receipts? I think the object on the "right" you refer to is actually on left in photo. It's the air blower for your spa.
    I hope this helps.
    Chris
    -Chris-
    2013 In-ground plaster/pebble, screen enclosed, 12000 gal w/ Jandy 2 speed 1 HP pump, Jandy CS 200 cartridge filter, 800 gal spa w/ 1.5 HP booster pump, Solar heater, 2 LED lights in pool 1 light in spa, TF-100 test kit, The PoolCleaner Next Generation, Jandy RS-12 Automation system with iAqualink 2.0 control, Separate Hayward/Goldline Solar control
