Results 1 to 9 of 9
Thread: TA Drop Normal?
    Matchless1's Avatar
    Jul 2014
    Baton Rouge, LA
    258
    TA Drop Normal?
    I started up my plaster pool (see sig for more details) on 7/4/16 and recently finished doing a SLAM after a big storm that threw all my levels off. I run a DEL Ozone EC-20 as my primary sanitation method and 10% LC for residual main body secondary sanitation (hence my low FC targets). I check FC, pH and TA daily and CH and CYA at least weekly, sometimes more often. Recent records shown below. As with any new plaster job, I have been adding acid just about daily to maintain my pH around 7.3-7.8. In doing this, I've noticed my TA steadily drops causing me to have to add baking soda every week to 10 days to get it back within the TFP recommended range. My question is, is this normal or should I be trying to troubleshoot something?
    Note: Just yesterday I added a considerable amount (more than normal) of acid while cleaning off calcium deposits on various stones around the pool, hence the spike (drop) in pH.
    14K gal, Diamond Brite Plaster (Bahama Breeze), Depth: 3.5' - 5.5', Pentair Intellipro XF VS Pumps (2), CCP520 Filter, Intellitouch i9+3S w/ ScreenLogic2, DEL Ozone EC-20 w/ Stenner Pumps for Chlorine & Acid, Flagstone Coping, Moss Rock Waterfall, Dolphin 15.5' Slide, Intellibrite 5G Pool Lights (3), Globrites (2), Kichler Underwater Waterfall Lights (4), Auto Leveler, 4'x8'Techno-Solis Solar Panels (14), Dolphin S300i Cleaner, My Pool Build
    VinDeeLoo's Avatar
    Jun 2016
    Tonkawa/Oklahoma
    204
    Re: TA Drop Normal?
    Muriatic acid will lower your TA.
    VinDeeLoo
    7600 gallons ~ AG ~ Summer Waves Cartridge C Filter ~ using pump that came with our Summer Waves 18 x 48 pool ~ Taylor K-2006 (SpeedStir & Sample Sizer) ~ no well water or water restrictions
    Matchless1's Avatar
    Jul 2014
    Baton Rouge, LA
    258
    Re: TA Drop Normal?
    Quote Originally Posted by VinDeeLoo View Post
    Sent from my iPad using Tapatalk
    Agreed and understood. Just trying to understand if the RATE of TA lowering is normal or excessive. Hoping normal, but also wondering when it might start to level off.
    VinDeeLoo's Avatar
    Jun 2016
    Tonkawa/Oklahoma
    204
    Re: TA Drop Normal?
    Put your numbers into pool math and it will tell you how much to expect.
    VinDeeLoo
    Sep 2013
    Connecticut
    728
    Re: TA Drop Normal?
    I think the poster's question is about the behavior of his two-month old plaster - i.e. whether the chemical demands are normal or not.
    Hopefully someone more knowledgeable about plaster will be along soon. Judging from other threads I've seen, I think it's not unusual for new plaster to take quite a number of months to settle into its 'mature' chemistry; but I know relatively little about this area of pool care, so wait for a more expert opinion.
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Re: TA Drop Normal?
    I agree with Vin, PoolMath will tell you how much MA will drop TA in the effects of Adding Chems section.
    Jun 2013
    GTA, Toronto, Ontario
    119
    Re: TA Drop Normal?
    Not to hijack, but where'd you get that spreadsheet? Seems pretty slick! Combine that with the brains behind pool math and I'm sure most would be using it to track, I know I would!
    77000L (20500 gallon) vinyl in-ground chlorine double roman pool, 35'x17', Hayward SP3200VSP, Jandy Lite2 LJ400N heater, Hayward S244TC filter, *deleted* Hayward chlorinator, Taylor CK1004FAS+CYA
    Aug 2014
    Houston tx
    2,524
    Re: TA Drop Normal?
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Matchless1's Avatar
    Jul 2014
    Baton Rouge, LA
    258
    Re: TA Drop Normal?
    Quote Originally Posted by Marlahoutex View Post
    That is correct. I love it!
