Results 1 to 7 of 7
Thread: My pool is a swamp
    Aug 2016
    Hudson, WI
    4
    My pool is a swamp
    Hi all - I am a newly single mom and new maintainer for pool we have owned for years. Have been doing ok with pool maintenance for the summer, but travelling alot the past couple weeks w/kiddos and it got away from me. Came home today to a pea green mess. We have an above ground 18x34, Doheney's above ground pool pump, sand filter, and automatic chlorinator (turned off because CYA was elevated to 100 at end of July). My FC and TC are at 0 and pH elevated at 8.2. Here are all my numbers as of 7 pm tonight:
    FC = 0
    CC = 0
    TC = 0
    pH = 8.2
    CH = 540
    TA = 120
    CYA = 50
    Insult to injury is the fact that the weather is cool enough and pool is not heated, that we will not likely swim in it again this season. However, my assumption is that I should stabilize it and bring it back to blue before closing. I added AlkaMinus from Menards tonight to bring pH down. How long after adding that can I begin to add chlorine? (guessing I should wait til morning and test pH again). I have 8.25% chlorine - also from Menards, 8 jugs for now. Pool math recommends 7.5 jugs to bring to shock level. I will have to get more chlorine tomorrow. I know its not great to add chlorine during daylight hours, but wondering if it makes a difference if it is a cloudy day?
    Am I on the right track? I also have a box of shock packets from Sams Club. Should I use those instead of the liquid chlorine? And what about an algaecide (I have a large jug of it in the garage)? Just trying to figure out the most cost efficient way to tackle this problem and potentially use stuff I already have.
    Finally, when should I do the closing process? Live in Wisconsin and nights are getting into the low 50s now. Days are low 70s. Light rain for next couple of days.
    Thanks for any advice.
    18x34 above ground pool. 52" depth
    chlorinator (currently turned off)
    TF-100 test kit
    non-heated pool (solar blanket during peak season)
    Hudson, Wisconsin
    May 2015
    Clarksville
    146
    Re: My pool is a swamp
    I would use the liquid chlorine, and try not to use the shock bags. they add cya. if your cya gets much higher your FC will also need to be much higher to be effective. the shock bags can also add combined chlorine.
    normally you would use Murionic acid to lower ph, but this yr I was using chlorox ph reducer to lower ours just because I already had it from last yr. I haven't heard of it being bad to add chlorine during the day. with your cya level where it is, should be fine either way. you shouldn't have any FC loss with a 50 cya.
    vinyl soft sided pool
    intex 1500 gph sand filter and intex swg at 1500 gph.
    Aug 2016
    Hudson, WI
    4
    Menards was nearly out of all pool chems. They did not have any Murianic acid. So I bought their pool brand called AlkaMinus. Hope it works ok.
    TF-100 test kit
    Hudson, Wisconsin
    Aug 2014
    Northern IL
    4,615
    Next time try the paint section for muriatic acid (MA).
    Once your pH gets between 7.2-7.4-5, go ahead and slam. It will so much easier come spring. Pool School - SLAM - Shock Level And Maintain
    Oh, and for closing, wait until your water temps stay below 60 degrees.
    May 2015
    Clarksville
    146
    sorry I misspelled muriatic acid. Google keeps telling me it's wrong although I now have it right + no proper suggestions. I guess it doesn't recognise that word.
    Aug 2014
    Northern IL
    4,615
    We knew what you meant. No worries!
    May 2015
    Clarksville
    146
    thanks 😍😍
