Thread: AquaRite SWG Lights Not Working Properly
    Sep 2016
    Ottawa, ON Canada
    3
    Hello. Long time lurker, first time poster.
    My AquaRite SWG its displaying a pattern of light discussed in other treads on this forum:
    Both Power light and Generating light illuminate once the No Flo light extinguishes. They stay on for a few seconds and then go out. Voltage and instant salinity suggest no chlorine is being generated. After reading other treads on this site, I opened up the panel, thinking the problem could potentially be a thermistor. It appears this is the case. However my board looks different from those in videos and photos that I could find posted here. It has the model number G1-022056-1 RevC. As such I am asking for some confirmation on my suspicions. Here is a picture of my board a close up of the part I think has failed given the brown discolouration at the base.
    My questions are 1) Am I on the right track with my thinking? and 2) If so, is this the part I should use for a replacement (it appears to be different from thermistor models mention elsewhere)?
    Thank you in advance for the help.
    Mark
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,014
    Re: AquaRite SWG Lights Not Working Properly
    You are on the right track, and thats the part. If you squeeze it, it will probably crumble.
    The part number on the current limiter is a Hayward P/N. The one you order is manufactured by someone else, so different p/n.
    Google replacement for..... and type that p/n, and you'll come up with the right one.
    Divin Dave,
    If your voltage with the switch off is less than 30, it’s probably a bad thermistor. If the voltage while generating falls below 20, it’s probably a bad thermistor. You can use part number SL322R025 or AS322R025.
    Your part is cracked and likely bad. You can see a circular crack near the edge. Typically, that means that the internal parts have separated.
    The Digikey page you linked to is the correct part.
    Support the site
    Sep 2016
    Ottawa, ON Canada
    3
    Thank you so much for the replies. I will post with the outcome after I have received the part (it did crack when I squeezed it).
