Thread: SWG saying "cell inspect due"
    Apr 2016
    Merrick/NY
    21
    Just noticed this on the SWG...what does it mean? What should I do?
    TIA!
    15K gallons, IG free form, concrete construction, vinyl liner, Jandy DE filter, SWG, Heat Pump, water restrictions. Located in northeast
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,541
    Re: SWG saying "cell inspect due"
    Some SWGs have a timer that sends out that message after so many hours of operation. Look in the manual for your specific SWG and see what it says about resetting the timer.
    On the other hand, if it has been a year, or so, since you visually looked inside your cell and made sure it was clean, you can also do that.
    Jul 2014
    Hope Mills, NC
    567
    Mine comes on every 30 days. Hold the reset button down for 5 seconds and it goes away. I know my cell is clean...
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    hoskim's Avatar
    May 2016
    Berkeley Heights, NJ
    83
    I always thought the light was "duration / hrs of operation"-driven. I check the cell, clean the debris, if necessary, and just reset. I once acid-washed the cell but it was unnecessary
    25,000 Gal, in-ground w/ vinyl liner
    Hayward SP2303VSP (1.5 HP) / DE filter (4820)
    Aqua Rite SWG / T-CELL-9 (v1.5)
    Polaris 380, PB4-60 Booster Pump (post-2012) / Aqua Heat Pump (S95)
    TF-100 Test Kit with Speedstir
