Thread: Closing AGP for first time with SWG and hard plumbed piping
    Jan 2010
    Randleman,NC
    620
    Suggestions on the best way to winterize equipment since will not be removing for storage this year.Also in North Carolina so our winters are short.In the past I have Raises Chlorine and lowered water and cover pool.Would pull and store pump.
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,248
    Re: Closing AGP for first time with SWG and hard plumbed piping
    If you blow out the lines, water will be removed from the Sand Filter and pump, including the plumbing lines. Here is information on the Sand Filter:
    winterizing with a sand filter
    Post # 11 (although recommend reading the whole post)
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
