Thread: pump and filter distance
    i have a 24 foot ag round pool with a 1 hp pump and sand filter plumbing it with flex hose how far away can i be from pool before i start to lose some pressure etc.... 20 ft 30 ft etc...
    thanks,
    mike
    Above ground 33 ft round 52 in. high
    Approx. 25000 gallons
    Hayward Dreamline Sand filter holds 250lbs sand
    Hayward CL-200 chlorinator
    Hayward 1.5 hp 67 GPM pump
    Re: pump and filter distance
    You start to lose pressure the instant you make the hoses longer, but it doesn't become significant for some while. Depending on how far you want to go, you might want to use a larger diameter rigid PVC, which will have less flow resistance than flexible hose. With oversized rigid PVC you could probably go over 100 feet.
    thanks for the info. would i still use flex hose to connect to pool skimmer and return?
    i dont want to bury any pipe.
    thanks,
    mike
    There are lots of different ways you can do it. Flex hose is fine as long as you keep the pieces of flex fairly short, like 3 to 6 feet each, and use PVC for most of the distance.
    would i have to bury rigid pvc to span about 20-30 feet?
    frankthailand's Avatar
    Apr 2008
    Thailand
    152
    No only if you don't want to see it. and if you do bury it, mowing etc, you dont need to go deep, it is pretty tuff stuff use high pressure it will last a long time, years
    Hello all from the land of smiles. Thailand. 5mx9mx1.5 63000L 16300 gall, pebbletex,
    pentair 1hp whisperflow, tagelus TA60 SF, swg monarch esc24 {a bit small for the tropics} 3 returns, 1 skimmer, 2 astral 100watt lights. Planned and built by me
    an AUSSIE expat living thailand for 18 years.
