Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: Why is there no FC with SWG? Upd got it to 5! SWG throwing Service Light "121"?
    May 2016
    Dallas/TX
    276
    I just got salt mixed into my pool and I set the Jandy Aquapure to 30%, yet my FC levels remain 0. My CYA should be around 70-80, I am going to test today. My pH crept up to 8.2 again so I am going to bring it down with MA.
    I guess my question is: what do I need to do to get the Aquapure to start producing some Chlorine for me?
    12K Gallon, IG PebbleSheen Blue Granite, built AUG 2016, 4 Jandy nicheless LED lights , Jandy 2.0HP VS ePump, Jandy AquaPure PLC700 SWG, PB4-60 Booster pump, Polaris 280, Jandy CV580 VersaPlumb Cartridge Filter , Jandy - Pro Series RS4 W/iAquaLink, Jandy JXi400NK 400K Heater, OK Flagstone Coping, Travertine Decking, 7 x7 Spa, Tanning Shelf, 10' Grotto, TF-100.
    JoyfulNoise's Avatar
    May 2015
    13,191
    Re: Why is there no FC with SWG?
    How long has your FC been at zero for? If the water was left that way for too long, you could have the start of an algae bloom and your SWG will never be able to produce enough chlorine quick enough to kill it.
    I would raise your FC to your target level using bleach and then run the SWG from that point to see if it holds. I would also suggest that if it does not hold and your SWG has all normal lights on, then you need to do an OCLT to rule out algae.
    Matt
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    570
    How long has the salt been mixing? You should let the pump run for about 24 hours and then turn on your salt water generator and it should show free chlorine.
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
    Aug 2014
    Houston tx
    2,524
    Salt will maintain your FC level pretty easily, but you'll need to bring the FC up to your target range with bleach, as stated above.
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    May 2016
    Dallas/TX
    276
    My mistake guys, I have somewhere between .5PPM and 1PPM of Chlorine.
    My CYA is excellent, somewhere around 80-90. Little higher than I wanted, but should be fine?
    Added in around a cup -1.5 cup of MA to lower pH.
    Added in around 60os of Bleach to get the chlorine level higher to get me to 4PPM.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,868
    I would definitely raise my chlorine with liquid chlorine and then let the SWG maintain it.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Jul 2014
    Hope Mills, NC
    567
    Your FC neens to be much higher than 4. At 80 CYA you need around 7
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    May 2016
    Dallas/TX
    276
    Quote Originally Posted by Griswald View Post
    I figured it needed to be higher than 4, I just wanted to start slowly. I'm going to test tonight and then dump more bleach in if needed
    dsmith99's Avatar
    Jun 2016
    SW, Iowa
    222
    Do not fear overshooting a little on your chlorine, running with a low chlorine level is MUCH worse than a little too much. Any time your chlorine gets below your minimum you risk letting algae get started, the longer it runs there the larger the risk.
    With a CYA level of 80 your pool is perfectly safe to swim in up to 31 ppm chlorine, so 10 or 12 will certainly not hurt a thing. The extra chlorine may even be a good thing if you have something trying to get started.
    Pool School - Chlorine / CYA Chart
    AGP 24' x 54" approx 14000 gal Full sun all day, Hayward 1.5 HP and EC50 D.E. filter
    Stenner 45MPHP10 10 gal/day fixed rate with intermatic ET1125C timer
    Dolphin E10 robotic cleaner, 330 gallon Tiger River Spa, Taylor K-2006C test kit
    May 2016
    Dallas/TX
    276
    Now I am confused.... I just tested today and I still have .5PPM of FC..... I literally dumped in half jug of Bleach yesterday and mixed it in.... Do I need to throw in 2 jugs of Bleach today?
    I just did the test... dropped the powder into 10mL, it turned a pink hue, then did 1 drop of solution, and it all disappeared.
    I called Jandy just now and they said I need to shock my pool.
    Jul 2014
    Hope Mills, NC
    567
    Re: Why is there no FC with SWG? Upd Still very low FC
    I get 140 ounces of 8% bleach to get to 8.0. At 6% you would need close to 200 ounces.
    Vinyl in-ground
    1 HP Pump
    Hayward SWG
    May 2016
    Dallas/TX
    276
    I poured in around 1/4 jug of bleach and cranked up the SWG to 80% (from 50%). I will re-test tomorrow. My pool literally gets direct sunlight for 12 hrs a day. Also, I did the CYA test and I am hovering around 90.
    kellyfair's Avatar
    Jun 2016
    Tampa, FL
    898
    Have you tried Pool Math to find out how much bleach you need to add to get to your target? I could be wrong, but it sounds like you aren't even close.
    Just did a quickie based on current value of .5 FC, 90 CYA and target of 8. With 8.25% bleach, you need about 130 ounces. So depending on the size bottle you are using, you aren't even scratching the surface.
    16' by 4' Intex Ultra Frame AGP
    Intex 120V Krystal Clear Sand Filter Pump & Saltwater System CG-28679 with E.C.O.
    Hayward Through Wall Skimmer, Intex Auto Cleaner - works great!
    TF100 Kit and Speedstir
    Get the Pool School ebook, free on Google Play!
    Aug 2014
    Houston tx
    2,524
    Cranking up the SWG won't really help that much either. You need to add the correct amount of bleach first before the SWG and before you get an algae bloom.
    Marla
    Jul 2014
    Hope Mills, NC
    567
    So now 2 people have told you to use between 130 and 140 ounces of bleach, that's more than one full jug.
    1/4 jug will NOT do it.
    Vinyl in-ground
    1 HP Pump
    Hayward SWG
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,521
    At your CYA level, it is safe to swim with FC up to 32-36. So dump a gallon of bleach in there and get your FC up now or you're just asking for algae. Running your SWG overtime to try to bring up your FC is just shortening its life. Personally, I'd much rather pay for a $3 jug of bleach than a $400 SWG cell.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    If you would listen to what these fine folks are telling you about adding MUCH more bleach than you are, you would be making some progress. Your SWG will maintain FC after you bring it up with bleach.
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
    May 2016
    Dallas/TX
    276
    In my defense, I put in what I had left at the time... it actually worked... my FC went up to 1.5PPM today.
    I went to Lowe's and bought the last two Kemtek Liquid Chlorine jugs and dumped one in... with a pinch of MA to lower the pH a little bit. Fingers crossed I get a spike then I will start tweaking with the SWG %. If PoolMath is correct, I should get close to FC10 (possibly more with SWG at 75%)
    Thanks!!!!!!
    kellyfair's Avatar
    Jun 2016
    Tampa, FL
    898
    Re: Why is there no FC with SWG? Upd Came to 1.5FC, put 1gal in tonight
    Make sure you don't add bleach and MA too close together, dangerous. Give one time to be mixed in, pump on, before adding the other.
  20. Back To Top    #20
    May 2016
    Dallas/TX
    276
    Quote Originally Posted by kellyfair View Post
    20-30 mins enough time?
