Thread: Question regarding mounting solar reel
    Sep 2016
    St. Paul, MN
    1
    I have a 18ft round above ground pool with curved rails on top. Solar reel mounting requires flat surface. Any conversion kits available or do you have any suggestions? Would like to mount to pool rails vs. using posts. Thanks!
    KazzyK810's Avatar
    Jul 2016
    Davison, Michigan
    75
    Re: Question regarding mounting solar reel
    Sorry, no one replied to you. I have an 18 ft intex pool so I don't have the standard above ground pool top rail. I thought about buying a reel and mounting to posts, but I didn't want to see anything above the pool, so I built my own solar cover holder out of PVC pipes. I've tweaked the design a bit since my first attempt, but so far, it's working out great and is easily removable for winter.
    Karan - 18 ft round x 48" high - Intex ultra-frame AGP, Intex 3/4 hp pump with 14" sand filter (SF70110), Hayward 900 Wanda the Whale cleaner, Intex LED water fountain.
    18ft Round Intex Ultra Frame in The Mitten
    titleistseemore's Avatar
    Jul 2014
    Lodi Ca
    189
    I mounted mine behind the pool, using wood. Mine is similar to the one cowboy casey did. The link to the page with some photos is below ...
    New above ground oval 18x33 install - Page 7
    Tim Jacobsen Lodi Ca.
    18'x48" Intex Ultra Frame (5700 Gallons)
    TF 100 Test Kit, Speedstir, & Sample Sizer. Liquidator Installed.
    Hayward C550 Cartridge Filter (55 Sq. Ft.), 1HP Powerflo LX Pump, Pool Rover Jr.
    http://www.troublefreepool.com/threa...uild-Questions
    Jul 2016
    sacramento
    17
    could you post a pic please? I'm interested in your design.
