WHERE IS THE WATER GOING? Pool leaking only when filter is off
Hulligan
56
Hull, GA
Hello, I have seen this issue addressed in other posts but not exactly like my situation. I have a vinyl lined inground pool, with a Hayward sand filter. I will lose about 3 inches overnight if we turn the filter off. If we leave the filter on all day and all night we don't lose anything. 3 inches of water is a lot and we cannot figure out where it is leaking from, and where is this water going? Any advice on how to diagnose the leak? Thanks so much
Sometimes the ground water and dirt will sort of plug the hole when the pump is running and let it trickle out when the pump is off. I saw one suction leak that wouldn't leak for the first 30-60 min because it would suck all the leaked water back in and once it was gone it would start sucking air. Suction leaks can be weird and hard to find.
