Results 1 to 9 of 9
Thread: WHERE IS THE WATER GOING? Pool leaking only when filter is off
    Apr 2015
    Hull, GA
    56
    Hello, I have seen this issue addressed in other posts but not exactly like my situation. I have a vinyl lined inground pool, with a Hayward sand filter. I will lose about 3 inches overnight if we turn the filter off. If we leave the filter on all day and all night we don't lose anything. 3 inches of water is a lot and we cannot figure out where it is leaking from, and where is this water going? Any advice on how to diagnose the leak? Thanks so much
    Inground, vinyl pool.Hayward Sand filter. 24,200 gallons.
    RonsPlc's Avatar
    May 2015
    Gaylesville, AL
    459
    Re: WHERE IS THE WATER GOING? Pool leaking only when filter is off
    when you are running your pump, is air coming out of the return(s)?
    Is suspect that you have a suction side leak.
    14600 gal Intex 24' Round 52" deep AG Pool (Heavily Modified)
    200lb sand filter w/2 speed 1.5/0.5hp pump
    Stenner 45MHP10 Liquid Chlorine (well... bleach) Injector. Borates added.
    K-2006 test kit w/Speedstir
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Apr 2015
    Hull, GA
    56
    There are no air bubbles coming out of the returns. Also, no telltale water spots on the lawn or around the deck that would indicate where this water is going. Or coming from.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Agreed, it is likely a leak on the suction side underground. Elbows under skimmers are the culprit sometimes.
    Apr 2015
    Hull, GA
    56
    This may be a silly question ... But does that mean I hire a pool guy to come take a look at it? Is there anything a homeowner can do to try and figure out where the leak is if it's underground?
    DFW, TX
    24,514
    Leak detection companies have special equipment that tracks down leaks.
    Here are a couple of articles from Pool School on leaks
    Pool School - Leak Detection
    Pool School - Suction Side Air Leaks
    Aug 2014
    Northern IL
    4,615
    I hope you don't mind me side-tracking this a bit, but I don't understand how the pool DOESN'T leak with the filter on, but does when it's off. When the filter is off, is the pump off too?
    DFW, TX
    24,514
    Sometimes the ground water and dirt will sort of plug the hole when the pump is running and let it trickle out when the pump is off. I saw one suction leak that wouldn't leak for the first 30-60 min because it would suck all the leaked water back in and once it was gone it would start sucking air. Suction leaks can be weird and hard to find.
    Apr 2015
    Hull, GA
    56
    Thanks for the advice everyone. 😊
    Yep, we were wondering that as well. And, WHERE is all the water going? Ugh.
