Thread: Scale or something else (with pictures)
    ITR's Avatar
    Nov 2014
    Clermont, FL
    320
    Hey guys. Here are a couple of pictures of what I have thought has been scale on the Stonescapes finish. After a year of trying to tackle it and keeping CSI in the negative I'd like a more professional opinion. Do you guys think this is scale or possibly something else?
    15' x 29' 10,300 gal w/ spa, IG-Plaster (Stonescapes Tropics Blue), 2spd WhisperFlo pump (1.5hp WFDS-26), Pentair Clean and Clear CC200 cartridge filter, Pentair MasterTemp 300BTU heater, Clear o3, RS-8 iAqualink
    JoyfulNoise's Avatar
    May 2015
    13,173
    Re: Scale or something else (with pictures)
    If it were scale, it would be raised above the surface of the paster and feel rough. You'd have to dive down with a mask on to really see it clearly. You could try wet sanding a very small area with a fine sanding sponge to see if the variation goes away (you remove something).
    Since this is a dark plaster color, it honestly looks like some mottling that occurs do to poor workmanship OR it's just color bleaching. Many people avoid dark plasters because, if they can survive the initial application without getting bad mottling, they typically suffer from color bleaching over time. Even the blue colored plaster creme in my standard Caribbean Blue PebbleTek (probably one of their most basic colors) has faded noticeably over the years. I can only imagine how quickly darker shades of plaster degrade over time.
    Matt
