is light Ok?
engrav
Platinum Supporter
563
Whidbey Island, WA
Old pool and old light as in signature. Never used light before but tonight kids swimming so light on.
Got to wondering, how do I determine if light wiring is proper and sound?
Thank you.
If your light is controlled by your EasyTouch, then you can look inside and see if the relay being used to turn on the light is being fed by a GFCI circuit. It could be from an individual GFCI breaker, or by the GFCI outlet, often installed in the panel.
If the power to the light is not coming from a GFCI circuit, then I would not use the light until fixed.
Jim R.
1) I am no electrician
2) I will get an electrician
but for fun
see any GFCI stuff in these pics of circuitry to light?
