Results 1 to 10 of 10
Thread: is light Ok?
    Jul 2012
    Whidbey Island, WA
    397
    is light Ok?
    Old pool and old light as in signature. Never used light before but tonight kids swimming so light on.
    Got to wondering, how do I determine if light wiring is proper and sound?
    Thank you.
    IG under fir trees and one cherry surrounded by grass built in 1979, 30k, plaster, old Sta-Rite HRPB30, 4.9 sq.ft, 20 GPM/sq.ft., but with new glass, new (in 2012) 1 HP WhisperFlo one speed, new (in 2013) Rainbow tab chlorinator attached at the top, old Maxi-Flo Heat Exchanger MF-260, Burnham V7 oil heater 245 MBH, new (in 2012) Compool to Easytouch, Taylor K-2005 and TF-100.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,460
    Re: is light Ok?
    If your light is controlled by your EasyTouch, then you can look inside and see if the relay being used to turn on the light is being fed by a GFCI circuit. It could be from an individual GFCI breaker, or by the GFCI outlet, often installed in the panel.
    If the power to the light is not coming from a GFCI circuit, then I would not use the light until fixed.
    Jul 2012
    Whidbey Island, WA
    397
    Re: is light Ok?
    thanks, will check it out
    Jul 2012
    Whidbey Island, WA
    397
    Re: is light Ok?
    1) I am no electrician
    2) I will get an electrician
    but for fun
    see any GFCI stuff in these pics of circuitry to light?
    Jun 2015
    Central, NJ
    566
    Re: is light Ok?
    I am no electrician but No GFI there. But could be at switch or a GFI breaker.
    27,000 gals (20 x 40), IG, vinyl, Hayward Sand Filter S244T 300LB, Hayward
    Super pump SP 2607X10 1 hp.
    Jul 2012
    Whidbey Island, WA
    397
    Re: is light Ok?
    Quote Originally Posted by Pool Amateur View Post
    thanks so dug further, see pic below
    breaker #1 is labeled pool light switch, different from all the rest
    is that a GFCI breaker?
    Jul 2014
    Bedford, TX
    7,460
    Re: is light Ok?
    Yes it is.. you are good to go..
    Jul 2012
    Whidbey Island, WA
    397
    Re: is light Ok?
    bingo
    thank you
    Oct 2014
    Villa Park, CA
    52
    Re: is light Ok?
    You should test it. Push the red button, the GFCI should trip, the light should go out.
    20' x 40' 30,000 gallon IG Plaster with Spa, wading pool, fountain built 1993
    Pentair 011018 IntelliFlo / 2HP fountain pump / 2 HP spa jet punp / Jandy Ji8000 controller with IntelliComm II interface to IntelliFlo
    Crystal Water Aqua Clean 60 Sq ft DE filter / FlowVis Flow / Stenner DIY Chlorinator / The Poolcleaner 4-wheel / Taylor K-2006
    Jul 2012
    Whidbey Island, WA
    397
    Re: is light Ok?
    so did it
    light on
    hit test button
    breaker tripped
    light went out
    double bingo
    thanks much
