Thread: Test kit - where and which exact kit do I buy?
    morzh's Avatar
    Jul 2015
    Jackson, NJ
    238
    That test kit everyone refers to here - where is it sold and does it come with all tests included or do I add them separately?
    Also, when do I need OTO test and when FAS?
    Seasonal World rectangular pool, 27K gallons (data sheet), 25.3K calculated
    Jandy Stealth JHPU 2.0 PUMP, 2HP
    Jandy CL340 cartridge filter
    Pentair C320 inline chlorinator
    AquaComfort heatpump heater
    VinDeeLoo's Avatar
    Jun 2016
    Tonkawa/Oklahoma
    204
    Re: Test kit - where and which exact kit do I buy?
    Get your test kits from TFTestkits.net
    I suggest the tf100. It won't have the salt test - not sure if you have a swg. You can purchase one at same place if you need it. You will not need oto test. The fas-dpd is what you use.
    VinDeeLoo
    7600 gallons ~ AG ~ Summer Waves Cartridge C Filter ~ using pump that came with our Summer Waves 18 x 48 pool ~ Taylor K-2006 (SpeedStir & Sample Sizer) ~ no well water or water restrictions
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    360
    I use the OTO test every day, use the full kit once a week. Once a pool is properly balanced and maintained, not much is required....unless a tropical storm like Hermina drops 13" of rain in 8 hours, or your gfci kicks off due to a storm while you are out of town....but that's why you have the full test kit to rely on. Check CL and PH daily with the simple kit, total chemistry once a week with the big one.
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 1hp Pentair Superflo pump.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Some people use the OTO test during the week and the more costly and more accurate FAS-DPD test once per week, others like myself almost exclusively use the FAS-DPD, although the OTO is good to have around as a sanity test. The OTO reagents are very cheap (refills of OTO solution are only about $1 or so) and TF-Teskits can make up the TF-100 by including the OTO/pH combo kit in it for less than it would cost them to include a pH only reagent and the cost of the pH only test block. So in a way the OTO test is a freebie thrown in.
    Aug 2014
    Northern IL
    4,615
    I have a K-2006C and love it.
    I have an OTO and I never use it.
