Thread: Hayward northstar t ring
    Jun 2016
    Austin, TX
    334
    Does anyone have any tips for getting this pump basket to seal. I even bought an entirely new lid with new t seal, lubed it up and it still suckling air. This model has no o ring that I can see just a t shaped seal that fits ina groove in the basket lid.
    13k Gallon IG Pebble w/ attached Spa, AquaRite T-Cell-15 SWG, Hayward DE6020 Filter, Hayward 2 HP Pump, Hayward 400k Heater, TF-100 Kit, Pool Logger
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Hayward northstar t ring
    Try tightening the lid further with the pump running. When removing it, you may need to loosen it the same way.
    Mark
    Jun 2016
    Austin, TX
    334
    It won't budge anymore. At least by hand. Hmm.
    mas985's Avatar
    Pleasanton, CA
    11,737
    The basket area could be warped or have crack.
    Mark
    Apr 2015
    tucson, arizona
    1,118
    Did you check the union o-ring in front of pump
    Jun 2016
    Austin, TX
    334
    I have not but if I use a hose an run it over the lid the bubbles go away, must be something going on with warping or something like Mark said. I might have someone come take a look that knows more than I do about these things.
