Thread: 8.4 pH pool
    Sep 2014
    Los Angeles CA
    40
    8.4 pH pool
    Hi, I haven't been adding anything to the pool except liquid chlorine. When I last measured it the pH was 8.4 or thereabouts. I thought liquid chlorine pH changes were supposed to be temporary and balance out at the end. Will I have to add muriatic acid? At what chlorine level is it safe to swim in if any?
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,105
    Re: 8.4 pH pool
    We need the details of your pool and testing method before we can honestly address your concerns.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    domct203's Avatar
    Jun 2015
    CT
    3,591
    Re: 8.4 pH pool
    Quote Originally Posted by Jarwulf View Post
    What is your TA? Rising pH is a common situation, most pool owners find that pH will rise over time and use muriatic acid to lower it.
    You are safe to swim when the FC level is between 7.5-40% of your CYA level.
    Could you post a complete set of test results including FC, CC, pH, TA, CH & CYA? This will help us understand your pool.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
