Thread: Looking to go BBB
    Looking to go BBB
    Also looking to go BBB. Quick add-on to this question;
    pH - 7.4
    TA - 90
    FC - 0
    TC - 0
    CH - Unknown
    CYA - 0
    Fresh pool fill. (Added 3 gallons 6% liquid chlorine 2 days ago, we have had a bit of rain over the past two days.) I will be adding 214 oz of liquid chlorine tonight (per ThePoolCalculator).
    Pool gets sunlight 6:00 AM - 8:00 PM. Does anyone have a preferred stabilizer/conditioner to use with the BBB method? I'm planning on liquid chlorine with possible pucks in the auto-chlorinator.
    Any recommendations to a complete newbie?
    -Woody
    32' x 16' - 17,200 US Gal. - In-Ground Concrete/Plaster
    Emerson Extreme Pump (EB841 1HP) - Hayward S244S Sand Filter
    Rainbow Lifeguard 320 Inline Chlorinator
    Jan 2009
    Cupertino, CA
    1,966
    Re: Just to clarify...about cya
    Quote Originally Posted by TeJaWood
    General recommendation is to add cyanuric acid (CYA, aka stabilizer) directly, 30-50ppm, then use bleach for a chlorine source. Pucks will continue to increase your CYA, which will become a problem in the long run. In the short run, they won't add CYA fast enough to be helpful.
    --paulr
    BBB "Intermediate Swimmer"
