Thread: CYA rose to 95 over two weeks from 58 - could tge tabs bring it this fast?
    morzh's Avatar
    Jul 2015
    Jackson, NJ
    238
    At the beginning of the season I tested my water in the store I go to with computerised testing.
    It showed 58 CYA - quite a bit down from last year wgen I was at 98. (Yes I did use that bacterial bio stuff and it did seem to work....kick me).
    Anyways, I was away for two weeks and so I put 6 jumbo tabs in the chlorinator to keep the pool chlorinated in my absense. The pump ran 5hrs per day and for now it looks like no more than half is used up.
    Today I decided to test the water (had a light algae bloom so after I squished it I decided to test for CYA) - the same store showed 95.
    So, the only reason I was using tabs was I was hoping it would not raise CYA too much given the amount (6 tabs in inline chlorinator, again by now about 3 have been used judging by the height of the tabs column in the chlorinator).
    Could tbey? Or is it the test error?
    Seasonal World rectangular pool, 27K gallons (data sheet), 25.3K calculated
    Jandy Stealth JHPU 2.0 PUMP, 2HP
    Jandy CL340 cartridge filter
    Pentair C320 inline chlorinator
    AquaComfort heatpump heater
    VinDeeLoo's Avatar
    Jun 2016
    Tonkawa/Oklahoma
    204
    Re: CYA rose to 95 over two weeks from 58 - could tge tabs bring it this fast?
    Why aren't you testing your own water?
    VinDeeLoo
    7600 gallons ~ AG ~ Summer Waves Cartridge C Filter ~ using pump that came with our Summer Waves 18 x 48 pool ~ Taylor K-2006 (SpeedStir & Sample Sizer) ~ no well water or water restrictions
    domct203's Avatar
    Jun 2015
    CT
    3,595
    Six 8oz trichlor tabs would only add 7.4ppm of CYA in your 27K gallon pool.
    The result of CYA 58ppm was a test error, and this is why we stress the importance of doing your own testing.
    No one is going to "kick you" for trying the Bioactive, as a matter of fact, if you had success with it that is encouraging to hear. Was the CYA reduction observed with your own testing, or was that also from pool $tore testing?
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    morzh's Avatar
    Jul 2015
    Jackson, NJ
    238
    Quote Originally Posted by domct203 View Post
    Domct
    From the store. I go to the same store so I was hoping that even if their testing is off (and these guys do not even sell the blue box kits saying thowe are inaccurate, they test by computer and for free so....) at least it would be consistent, so if it goes up, at least I know it goes up.
    As for the bio CYA reducer, I know it is not popular but I did not know it. The first one didn't do much, maybe 10ppm, but then they want you to wait till below 5ppm FC and if I did that with CYA this high it'd be like having no FC at all, so I put it in at maybe FC of 5ppm. I called the mfr and they promised to send me some "pro strengh" that is more potent. This took some time and when it came it was some time in October so the water was cooler than what they ask for, though now FC was about right for them. I put it in shoryly before the pool closing. This May I tested the water upon the pool opening and it was 58ppm. This is why I thought it worked. Now I am not so sure it did.
    The guy in the store said the 58ppm could've been the result of the water temperature being low at the opening, but then it was not that low, probably close to 70F, plus the bottle is small and the water likely warmed up anyway. In any case, one of these measurements is flawed.
    One thing I noticed though, last year before the reduction attempt the FC would linger about 7-8ppm for a week without dropping (which was why I got interested in my CYA figure in the first place); this year after I would add a gallon of Great value 8.2% bleach and get the FC to about 5ppm (I always add before the bedtime when it's dark) it would get back to about 3ppm within 3-4 days. Which kinda indicates to me the CYA was somewhat lower.
    Make of it what you will.
    PS. Yep, need to buy that kit. I will.
    May 2015
    Fort Mill, SC
    179
    Do your own test, the CYA results are the last thing I would trust from the pool store. My store produces reasonably accurate results on everything but that.
    20K gallon vinyl inground pool, Hayward Pro Series sand filter, 1 HP pump, Taylor K-2006
