Thread: Hayward Goldline Aqua Pod Programming
    I've had this system set up since the pool was put in 3 years ago. The remote was never set up to control the heater - I don't remember why - so we've just controlled the heater manually from outside, no big deal obviously. However I was just thinking I might as well have the heater hooked up to the remote, so I checked the manual & looked on line, and I can't seem to find any instructions for doing it! I'm hoping I am just missing something & it's an easy thing to do, not sure why it wouldn't be. Any guidance would be much appreciated, and it will make a nice little Labor Day gift for the family.
    Thanks!
    Andy
    20k gallons
    In ground plaster pool
    Pentair C420 filter, Pentair Whisperflow 2hp
    Spa
    Apr 2015
    tucson, arizona
    1,126
    Re: Hayward Goldline Aqua Pod Programming
    Would help if you can give a model of the control system and heater. Usually you run a two wire low voltage cable from control center to heater. But some installations are different on different heaters and control systems.
