Thread: High ph
    Aug 2016
    Burleson, TX
    6
    High ph
    I can't seem to keep my ph down. I use muratic acid to get it down to 7.5 and a week later it is well above 8 again. Please advise.
    10,500 gallon in ground plaster with attached spa
    Sep 2013
    Connecticut
    728
    Re: High ph
    Do you have fairly new plaster? Any water features that aerate the water?
    Can you post a complete set of test results, please?
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    Jun 2010
    Glendale, CA
    513
    Re: High ph
    A full set of test results would help.
    High TA will drive PH up - as will aeration of the water. Does your spa have an attached waterfall?
    Typically the plan is to lower your TA to 60 or so and see if the PH stabilizes.
    16K Gal Plaster | Compupool SWG | Intelliflow VF | TF-100
    Aug 2016
    Burleson, TX
    6
    Re: High ph
    FC 3
    CC 0
    TA 125
    CH 220
    PH over 8
    CYA 35
    the waterfalls are turned off due to the fact that I have heard that it increases ph.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Re: High ph
    You would probably be well served to lower your TA.
    Pool School - Lower Total Alkalinity
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
