Thread: Pentair ic20 Cell Light In Boost Mode
    Apr 2015
    Neptune Beach
    4
    I cleaned and put my SWG (Pentair ic20) in boost mode because I had no chlorine. While in boost mode the green cell light is green most of the time but ocassionally it turns off for 5-10 minutes which I understand indicates chlorine is not being produced. Since I'm in boost mode shouldn't the cell light be green and remain green 100% of the time?
    JoyfulNoise's Avatar
    May 2015
    13,252
    Re: Pentair ic20 Cell Light In Boost Mode
    When you put it in BOOST mode, did the Sanitizer Output LEDs scroll? They should do that for the full 24 hour cycle.
    FYI - If your FC dropped to zero, using BOOST mode is not the best way to raise FC quickly. You should use liquid chlorine to set the FC level and then run the SWG. SWG's will only very slowly raise FC levels and, during that time, you're leaving your water at dangerously low levels of FC where algae can get a foothold and start growing.
    Matt
