Thread: CYA Test
    Aug 2016
    Chapmansboro, Tn
    36
    CYA Test
    Just a quick question. Following directions, they say to put you back to the sun. When I do this as apposed to facing the sun, I get about 5 points difference. Should I block sun out or I'm I being to silly about it? Thanks Bill
    New (Aug4th) AG, 8400gal, Ecokleer sand filter (45gpm max)
    1 1/2 hp Century ecokleer pump, Taylor K2006 kit
    Jul 2014
    Hope Mills, NC
    569
    Re: CYA Test
    We dont do "5s" here. The best way to get results is the 10's method. Start at the 30, then the 40, then the 50 etc. Only look at the tube after filling to a 10, it makes much more consistant results.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    30,431
    Re: CYA Test
    YOur test results are fine. Do not worry about that tiny difference either way.
    The precision of the test is plus or minus 10 ppm and some say even plus or minus 15 ppm.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: CYA Test
    The general advice is to block the sun
    Aug 2016
    Chapmansboro, Tn
    36
    Re: CYA Test
    Tank's to all. Will just keep on keeping on. Bill
