Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Sta-Rite heater won't stay lit
    Feb 2015
    Cypress, TX
    35
    Can anyone help with my heater? It will fire up fine but only stays lit for 2-3 minutes and then shuts off. The "service heater" light comes on. Thermostat?
    ps0303's Avatar
    Jul 2011
    FL
    3,805
    Re: Sta-Rite heater won't stay lit
    Open up the unit and flip the round top over and see if any of the status LED's are lit. One could be lit which could potentially tell you what's going on.
    Paul
    Gastek Pool & Gas Services If you would like to provide a review of the help I provided, please use the following link to leave a review. Gastek Google review,
    Check out some videos on my YouTube channel - Gastekservices on YouTube
    Feb 2015
    Cypress, TX
    35
    Bottom right hand corner of the circuit board, LED11 is lite up RED and LED 10, in middle of board is lit up GREEN
    ps0303's Avatar
    Jul 2011
    FL
    3,805
    OK well I had hoped to see one of the other LEDs lit. How old is your heater? Natural or propane gas?
    Paul
    Feb 2015
    Cypress, TX
    35
    It's probably 6-8 years old. I bought this house used from previous owner who is a pool builder and installed. It worked fine last winter. One item of note... it flooded here in Houston this past April and there was standing water for a few hours up probably 6-8" on the heater. It stays lit anywhere from 30 seconds to 3-4 minutes.
    ps0303's Avatar
    Jul 2011
    FL
    3,805
    I would check to see if there is water in the canister. Remove the bottom bolt from the header and see if water comes out. If it does, it could mean you might have a leaking heat exchanger in which case the unit is done for.
    The unit was never completely submerged was it? Water completely covering it.
    Paul
    Feb 2015
    Cypress, TX
    35
    No never completely submerged. I would say just 6-8" up the sides. Ok I'll try that tomorrow and see what I find.
    Feb 2015
    Cypress, TX
    35
    When you say header, you're referring to the manifold correct?
    ps0303's Avatar
    Jul 2011
    FL
    3,805
    Quote Originally Posted by Bdurdin65 View Post
    Yes.
    Paul
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,712
    See the 4 bolts under my hand? The lowest bolt is the one Paul is referring to. You may also want to check the therm regulator. Its what my finger is pointing to. Just unscrew that cap, there is a spring in there so careful once you get the cap off.
    Factory Warranty Station for:
    Feb 2015
    Cypress, TX
    35
    Ok so good news I guess... No water came out when I unscrewed the bolt on the bottom. I removed the therm regulator as well but how do I tell if it is bad or not?
    Attachment 54334
    ps0303's Avatar
    Jul 2011
    FL
    3,805
    I hold it with a pair of pliers and then use a lighter to heat the bottom of it and see if the opens. Some people also put them in boiling water as well. Either way it will tell you if that part is working.
    If it has a scale build up on it then likely it will have issues opening up.
    Paul
    Feb 2015
    Cypress, TX
    35
    I dipped it in boiling water, it opens up ok.
    ps0303's Avatar
    Jul 2011
    FL
    3,805
    Then that part is working ok then.
    Inside the heater is a metal box which houses some wiring and the Fenwall module. There is an LED on the Fenwal. After to fires up and then shuts down, is the LED blinking?
    Paul
    Feb 2015
    Cypress, TX
    35
    So I open up the housing and fire up the heater to see if I can see anything else going on. I haven't opened up the metal box yet.... and I see this.... can't be good huh?
    Feb 2015
    Cypress, TX
    35
    Here is a close up of that area with heat off...
    Feb 2015
    Cypress, TX
    35
    There is nothing blinking on the Fenwall. It heats up for a few minutes then clicks off, and LED8 blinks yellow on the control board until it fires back up ~ 15 seconds later.
    ps0303's Avatar
    Jul 2011
    FL
    3,805
    Oh that unit is done for. Looks like the top has rusted away and no you do not have a sealed canister. I wouldn't do anything but replace the heater.
    Glad you posted the pictures. Pictures are worth a thousand words. Many times we hunt for answers to help people here and then when a picture or two gets posted, the problem becomes clearer.
    Paul
    Feb 2015
    Cypress, TX
    35
    I figured that was the case when I saw the corrosion and fire showing through. Just curious... is this whats making it shut down? Or could it be something else and just a matter of time before the corrosion gets worse? I can't even get it to turn on now. I will replace the heater. Sta-bil or Mastertemp a better heater?
  20. Back To Top    #20
    ps0303's Avatar
    Jul 2011
    FL
    3,805
    With the hole the blower isn't working like it should.
    If you have the space, invest in a Raypak. Much better simpler unit.
    Paul
