Results 1 to 10 of 10
Thread: "No Flow" continuously on
    Jun 2013
    Southeast Pennsylvania
    125
    Hi,
    I have a Nature2 Fusion Soft. I noticed the other day that I was very low on chlorine.....about .6 ppm. I jacked up the SWG to 100%. I tested today and I have 0 ppm chlorine. I then noticed today I have "No Flow" showing on the display......which I learned chlorine production stops.
    I pulled the Flow/temp/salinity sensor and it had no scale, but I did scrub it down as directed anyway. I also took a look at the cell and it looks mostly (97% +) clean.
    I cycled the power off and on and I still get "No Flow".
    Any ideas? This is the third season for the SWG....brand new pool 3 years ago.
    Doug
    13,500 Gallon Gunite Aggregate Finish, DE, SWG, 2.0 HP pump, 1.0 HP pump for 3 Sheer Descents
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    360
    Re: "No Flow" continuously on
    Perhaps some details and test numbers are available so we have something to work with?
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 1hp Pentair Superflo pump.
    Jun 2013
    125
    Vickery,
    What kind of details and test number are you looking for?
    Doug
    Feb 2009
    360
    TA, CH, CSI... all the others as well. But likely it is a hardware issue as much as a conductivity one. Does that unit use a mechanical flow switch or electronic?
    Jun 2013
    125
    here are some numbers
    TA - 110
    Free Chlorine - 0
    Combined Chlorine - .2
    pH - 7.6
    Calcium - 280
    CYA - 50
    I don't know what a mechanical flow switch is, so it must be electronic.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,566
    Doug,
    Well, seems to me that there are only two options..
    1. The actual flow is low, due to maybe a clogged filter.. What is your filter pressure.
    2. The flow sensor in your SWG is not working. Not sure how your particular flow sensor works, but on mine it is mechanical switch that I can "rubber-band" closed for a test if I wanted..
    Jun 2013
    125
    My pressure is fine.....18 psi. There is normal and plenty of flow coming out of the returns. I have a flow/temp/salt sensor that is in the back of the vessel. I guess what would help me is to know what a "switch" is
    Jun 2011
    Long Beach, CA
    2,790
    Is it still under warranty? Most likely the sensor needs to be replaced since the flow is strong and it is clean.
    Search for a workbook for the aquapure and you should find troubleshooting tests for it.
    Feb 2009
    360
    A mechanical switch typically uses a paddle that suspends down into the flow stream. Flowing water lifts the paddle and tells the machine that there is water flow. A broken paddle, or a missing magnet on the paddle (many use a magnet on the paddle and a magnetic reed switch inside the switch body) or debris preventing the paddle from getting within range of the switch tells the machine that there is no flow. High scaling could collect and impede the paddle. Or it may be electronic using a variety of flow sensor methods. Most units are mechanical for cost and simplicity. Electronic units can use multiple elements sensing temperature change, vortex variations or other methods.
    A loose connection or broken wire can also be a cause.
    Jun 2011
    Long Beach, CA
    2,790
    Quote Originally Posted by Vickery View Post
    It's not a mechanical type of flow switch. It uses the same flow switch as the Aquapure and it's widely known that the old style of sensors were not reliable. The new version seems to have solved the flow issues.
