Thread: Pentair Whisperflo Troubleshooting
    Jul 2015
    Dallas, TX
    91
    Question Pentair Whisperflo Troubleshooting
    Recently my Pentair Whisperflo WF-26 (1.5HP, single speed) cleaning pump quit working. Turn cleaner on, pump motor does not start, not even any sounds. I got on Youtube and found to first check the capacitor. It tested bad. Put in a replacement this morning. Same thing - nothing. Next checked, on both ends, that the shaft freely spins. It does.
    Not sure what to do next. Either the motor is (electrically?) damaged at some point past the capacitor or no electric is getting to the capacitor. Seem logical?
    Your help is appreciated.
    Thank you.
    26K gal, in-ground, spa, Wet Edge Satin pebble, Pentair Intelliflo VS-3050, Whisperflo 1.5HP, Clean and Clear Plus 520, MasterTemp 400, EasyTouch PS-4 and ScreenLogic 2, GloBrite LEDs, DeltaUV D-20, Paramount Clear O3 and PV3, completed July 2014, TF-100, full sun, city water
    Re: Pentair Whisperflo Troubleshooting
    When you turn the pump on, do you hear the relay click?
    Check that power is getting to the relay. Then check to see if power is getting past the relay when the pump is turned on.
    Support the site
    Jul 2015
    Dallas, TX
    91
    Quote Originally Posted by JamesW View Post
    What I found is that I do not hear the relay (at the control panel, yes?) when I turn the pump on. Additionally, I found in Screenlogic that the pump then appears in System Delays... I can cancel the delay and then the pump starts. I can shut it off normally.
    The cleaner pump might have a five minute delay from when the main pump starts. If you're trying to turn the pump on within five minutes of the intelliflo pump coming on, that's normal. If the intelliflo has been on for more than five minutes, the cleaner should start right away.
    Support the site
    Jul 2015
    Dallas, TX
    91
    I am aware of some conditions in which there is a delay - I just don't recall that there was ever a delay when the pool had not been on in a while and I turned on the cleaner. Though there is pretty few and far between so it may have always been that. What I know for a fact is that my pump cleaner pump works (regardless of the delay) after having changed the capacitor... it's running its schedule as normal again.
    Thanks for the response, JamesW.
