Results 1 to 16 of 16
Thread: Wait until pool water is 60 degrees to close?
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    201
    I'm in Little Rock and just bought a new cover and was looking forward to closing after labor day when I freshen up on the closing instructions in this forum.
    Seems to me the cost of cleaning up green pool in May is less than the cost of maintaining a pool for the next four weeks while i wait for the water to drop that low.
    Is there anything wrong with the way I'm thinking, ie- something else to consider?
    Intex 22' x 52" - Intex Krystal Clear Sand Filter Pump - flow rate: 2,150 gal per hour
    TFTest Kits TF-100
    Waiting to stop relocating until I build my dream pool!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    8,904
    Re: Wait until pool water is 60 degrees to close?
    I can't imagine a reasonable tradeoff between the cost of chlorine over a month being more expensive in inital cost and time of doing it than chancing opening to a green pool and the same costs involved in doing all that.
    Isaac-1's Avatar
    SW Louisiana
    6,709
    How much do you estimate it will cost you to maintain your pool for another month? Something seems wrong here
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    201
    Thats certainly one way to lool at it.
    Look at my posts and you'll see a black to clear pool in seven days. Maybe 10 gallons of bleach. I'll have the time next spring.
    What does it cost to run a pool a month now- ten gallons of bleach and my time. And the pump.
    TFTest Kits TF-100
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    201
    My energy costs is about 9.8 cents per kilowatt by the way for the engineers out there. I think I've read other forums about running a pump. While I always thought it costs about $20 a month to run it, sure does seem like about $50.
    TFTest Kits TF-100
    37,254
    You have to do what you think is best for you. 5 minutes a day to add bleach in the fall or a week straight of slam in the spring.
    How much you running the pump? Only need 2-4 hours now per day VS 24 hours in a slam.
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    201
    Thanks, running the pump significantly less will help. I was thinking it wasn't wise to run less than 8 hours a day.
    TFTest Kits TF-100
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,124
    Just run the pump a couple of hours to mix in the bleach and filter the water, vacuum once a week if there is any debris on the floor. If you close now the pool will probably be green in a week or two. The longer it is green, the longer it takes to clear.
    Love TFP? Become a
    TFP Supporter!
    Jun 2014
    Roseville, CA
    340
    I used to do that with an above ground pool because I could kill the algae in the spring, let it settle and siphon the debris out on to the lawn and not clog the filter.
    SWG: CircuPool (May 2014) SI30+Plus; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    201
    I have a couple of thoughts on this process. So I have had this pool open for probably 2 weeks with only two to four hours of the pump running a day. Is there any thought that 2 hours is not enough to circulate any chlorine that you have to add?
    The pool had a little algae sprout earlier this week. Scrubbed it, shocked it with bleach, and then vacuumed to waste.
    I may have a little difficulty reading the color chart to tell how much chlorine is in the pool. It may have gotten below the minimum.
    My wife is colorblind I think, so I just ordered more R-871😀
    TFTest Kits TF-100
    Mod Squad pooldv's Avatar
    DFW, TX
    23,669
    2 hours is plenty of time to mix added chlorine.
    LOL! Yes, the FAS/DPD chlorine test solves all color blindness problems!
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    201
    I finally got the R-871, and let me say it was rather quickly [thank you], and I think the problem with reading the chart sometimes is that my chlorine is well over 5 ppm [the top of the chart].
    I'm staring and asking my wife it is 3 or 5...and it's 8.5!
    Anyway, I'll give it a shot leaving this pool open another month. Thanks for the tips!
    TFTest Kits TF-100
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    201
    I'm closing it today folks. Thanks much expense to keep it open... and time. Those who suggest leaving it open love your pools more than I. Even if I have a black pool in April- I'm ready, see my picture from April 2016
    TFTest Kits TF-100
    YippeeSkippy's Avatar
    Jan 2012
    'burbs of Augusta, Georgia
    6,110
    In my opinion, pool closing is also an aesthenic issue but one that isn't often mentioned. I think one difference is leaving an inground pool open is just sort of nice to look at, whereas you probably aren't getting to look at much more than the sides of your pool, right? So closing it early isn't denying you that view and will save you money.
    Maddie- TFP Guide. 12K Fiberglass IG, Infinity 4000 automatic cover, SWCG, Hayward Sand Filter, Hayward 1.5 Pump, Doheny Discovery Robot, Savi Melody LED pool lights, outdoor speakers and other assorted doo-dads. Sundance Altamar Hot Tub.
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    201
    Can we talk the forum moderators into allowing a "like" or "thanks". Here's to you YippeeSkippy!
    TFTest Kits TF-100
    DFW, TX
    23,669
    Quote Originally Posted by cfclay View Post
    I would like this post, but alas ...
