Thread: New Pool reading
    May 2016
    ada, mo
    32
    New Pool reading
    Hi All! I have been following for quite a while. My pool has finally finished last week. I have new plaster and trying to keep up with readings although I am confused. Yesterday my PH was under 6.2 and TA was 20. They added muric acid and chlorine. Today my TA is 130 and PH is 8.2 (or higher) My FC is 16 and CH is 125.
    I am not sure what my next step should be if anyone could throw up some suggestions?
    Thank you!
    17,000 gallons free form. Pentair Intelliflo VS pump, Pentair Heater, SWG, Easy Touch.
    kellyfair's Avatar
    Jun 2016
    Tampa, FL
    926
    Re: New Pool reading
    Hello! Experts will be along shortly, but until then, here's some reading material for you:
    Pool School - Getting Started
    How new is your plaster?
    16' by 4' Intex Ultra Frame AGP
    Intex 120V Krystal Clear Sand Filter Pump & Saltwater System CG-28679 with E.C.O.
    Hayward Through Wall Skimmer, Intex Auto Cleaner - works great!
    TF100 Kit and Speedstir
    Get the Pool School ebook, free on Google Play!
    May 2016
    ada, mo
    32
    Thank you. It was poured last week and we officially filled it up 7 days ago. My readings are just crazy. I will add chlorine next day it reads zero chlorine. The PH goes from off the chart to way to low. I bought the test kit im just unsure if I should follow the method right now with the new plaster.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    The first 30 days of plaster start up are important to long plaster life.
    1st priority is to follow the PB/installer instructions for plaster start up
    2nd priority is to follow the plaster mfg instructions for start up
    Here are some
    http://www.sgm.cc/html_Pool/HomeOwne...chemistry.html
    Overview | National Pool Tile Group
    Pool Care Instructions Pebble Tec
    Then we can help fill in the blanks.
    Adding CYA will help protect your FC from the sun
    It is important to keep PH between 7.2 and 7.8 at all times, depending on what type start up your PB is doing.
    Have you done some reading here?
    ABCs of Pool Water Chemistry
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,481
    My suggestion is to relax...
    I'm sure you have seen this suggestion before.. So, go get your test kit and let us know the following:
    FC
    CC
    pH
    TA
    CH
    CYA
    Sounds like your PB is still taking care of the water. Is this true, or is he done?
    I suspect you have very little CYA and that is why your chlorine is being burnt off so quickly. All of these tests are somewhat interrelated, so it is important for us to have them all at the same time.
