Thread: Replace light fixture?
    Apr 2016
    Dacula/GA
    11
    My gfci trips whenever I turn the pool light on, the fixture is 11 years old. The gfci performs fine with the lights off. I replaced the bulb and gasket, let the fixture dry out but that did not fix the fault. I am thinking about buying and installing a new fixture $200 but want to know if there is anything else I should do or test.
    30,000 Gal, IG, Gunite, Spa, Aqua Logic, Jandy CL 580 Cartridge, Jandy LX Gas Heater, FAS-DPD, T-Cell-15 SWG, Polaris 280.
    Apr 2013
    Sacramento, CA
    2,769
    Re: Replace light fixture?
    As you probably already know that fixture includes the cord that runs to the junction box. The cord and fixture come as one piece.
    I would check all the connections in the junction box making sure it's all dry and the connections are tight.
    Apr 2016
    Dacula/GA
    11
    Thank you, did that last night and all was tight with no moisture evident. So looks like I will be replacing fixture and cord. Hoping the job is as easy as it looks on youtube videos.
