Thread: Manual Pool Filler Timer?
    Sep 2016
    Roseville
    15
    We just moved in to a new house with an in-ground pool. It has a manual fill valve by the house with a hose bib. The line runs under the concrete patio to the pool. We live in a warm area so the water loss is daily in the summer.
    Is it possible to add a timer to this kind of valve and run a minute per day to keep up with the water loss? Or is there a way to convert this type of manual fill to auto-fill?
    Thank you!!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Manual Pool Filler Timer?
    You can put one of those sprinkler timers on it if you want to. It might take more than a minute a day to keep up with evaporation though. Just depends on how big your pool is and how many GPM of water come through the timer.
    What I do is fill the pool to about 3/4 to an inch above the 1/2 way mark on the skimmer. It takes about a week to evaporate an inch. Then on Saturday, I do it again. In my pool it takes 45 minutes to add an inch of water. And, I set my oven timer to remind me to turn off the water!
    Divin Dave,
    Sep 2016
    Roseville
    15
    Pic of the hose bib manual fill for my pool
    Apr 2015
    tucson, arizona
    1,118
    Champion PCL-100-C 1 in. Automatic Actuator Glass Reinforced Nylon for Irrigation Sprinkler Systems, You will have to get a actuator like this then put on a irrigation timer.
