Thread: Water Leveler - Fill & Drain
    bxcrwlly's Avatar
    Dec 2012
    Central Florida
    120
    I'm looking for any info on a pool water leveling device that either adds or drains water to maintain a certain water level. All those I reviewed only add water. Since I live in Florida, I need a device that works both ways.
    11,600 gallon plaster salt pool & spa, IC20 SWG, IntelliPH, cartridge filter, 2.7HP IntelliFlo Variable Speed Pump, Gas Heater, Easy Touch System w/remote, 8 roof mounted solar panels
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Water Leveler - Fill & Drain
    there isnt a device that automatically drains water except a built in overflow pipe. Lots of folks have installed a 3 way valve between the pump and filter so we can divert water out of the pool if we have to.
    Divin Dave,
    bxcrwlly's Avatar
    Dec 2012
    Central Florida
    120
    Thanks DDave....I have the typical manual "waste/drain" install. Was looking for more of an automated solution to facilitate draining when away.
    setsailsoon's Avatar
    Oct 2015
    Stuart/FL
    467
    Dave,
    I have the same issue... it's a real pain here in Florida with my pool having neither an overflow nor a fill. I have this hose connection as you indicate downstream of the pump but it's a completely manual operation. It used to run all over the ground and make a real mess until I installed a buried pipe out to the curb. I'm thinking about putting an irrigation valve instead of the manual valve and operating it from a relay on my rs-12 controller. What do you think about this approach? It really irks me that I've spent all the money for the automatic controls and I still have to trudge over to the pool equipment to reduce my water level. So I'm thinking about trying this set up and if it works then adding a wifi level controller to actuate it.
    I'll keep you posted... may take a couple of weeks as I'll be out of town for next 2 weeks.
    Chris
    -Chris-
    2013 In-ground plaster/pebble, screen enclosed, 12000 gal w/ Jandy 2 speed 1 HP pump, Jandy CS 200 cartridge filter, 800 gal spa w/ 1.5 HP booster pump, Solar heater, 2 LED lights in pool 1 light in spa, TF-100 test kit, The PoolCleaner Next Generation, Jandy RS-12 Automation system with iAqualink 2.0 control, Separate Hayward/Goldline Solar control
    bxcrwlly's Avatar
    Dec 2012
    Central Florida
    120
    Chris....sounds like a great approach. I'll be interested in hearing about your success. Thanks!
