Results 1 to 7 of 7
Thread: FC 17 Ok to swim?
    Jul 2012
    Whidbey Island, WA
    398
    FC 17 Ok to swim?
    Hi
    Usually do bleach but in prep for a few days away, was fiddling with the Rainbow. Got a little aggressive with the settings and now FC is 17 (CYA about 40). And now some kids wish to swim. Ok to swim with FC 17?
    Thank you.
    IG under fir trees and one cherry surrounded by grass built in 1979, 30k, plaster, old Sta-Rite HRPB30, 4.9 sq.ft, 20 GPM/sq.ft., but with new glass, new (in 2012) 1 HP WhisperFlo one speed, new (in 2013) Rainbow tab chlorinator attached at the top, old Maxi-Flo Heat Exchanger MF-260, Burnham V7 oil heater 245 MBH, new (in 2012) Compool to Easytouch, Taylor K-2005 and TF-100.
    Jul 2012
    Whidbey Island, WA
    398
    Re: FC 17 Ok to swim?
    Found old post by Jason. Anything up to shock level is Ok.
    Mar 2015
    South Texas
    411
    With your CYA of 40, anything UNDER your shock level of 16 is okay to swim. I would wait a bit, and even then, I would wear old swimsuits that you don't mind fading. Yep you beat me to it
    15,000 gallon free form Viking fiberglass pool. Hayward Star-Clear Plus C12002 cartridge filter. Hayward Swim Pure Plus T-15 SWG. Testing with TF-100 Kit. 2 speed 1.5HP Supreme pump. Dolphin Nautilus robotic cleaner
    Jul 2012
    Whidbey Island, WA
    398
    Quote Originally Posted by nlindelldc View Post
    Got it, thanks. 17 is not under 16 but could not keep 'em out so let the swimsuits fade.
    Thank you.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    17 is close enough.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    You can use common 3% dollar store / drug store hydrogen peroxide to quickly neutralize FC, common brown bottle stuff neutralizes FC at about the same rate that the same amount of common 6% bleach adds FC.
    Aug 2014
    Northern IL
    4,615
    After the swimmer load tonight, you are probably under shock/slam level now!
