Thread: Pump Just Hums After Replacing Pump Seals...Help!
    hoskim's Avatar
    May 2016
    Berkeley Heights, NJ
    83
    Basically followed the direction on Youtube to replace my seals (since the pump was leaking). While I am not a "professional" handyman, I am ok with the work around the house.....as soon as I put everything back together, the pump just hums and won't start. Gave a rubber mallet thump, and of course, I primed just in case......any ideas?
    25,000 Gal, in-ground w/ vinyl liner
    Hayward SP2303VSP (1.5 HP) / DE filter (4820)
    Aqua Rite SWG / T-CELL-9 (v1.5)
    Polaris 380, PB4-60 Booster Pump (post-2012) / Aqua Heat Pump (S95)
    TF-100 Test Kit with Speedstir
    Dec 2014
    Houston, Texas
    134
    Re: Pump Just Hums After Replacing Pump Seals...Help!
    There should be shaft access on the rear of the motor. Usually takes a 1/2 end wrench, try and spin the shaft to see if it's hung up or stuck.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    Check the start capacitor. It is either behind the back cover on the motor or under a hump on top of the motor.
    Love TFP? Become a
    TFP Supporter!
    hoskim's Avatar
    May 2016
    83
    Wow...thanks for your quick replies. Happy to report two things...it works now and I am an idiot . While testing / troubleshooting with electricity on is not safe, I had to do so and found out (after testing each piece especially the impeller) that I "left" an extra piece of a rubber o-ring which belonged to the old impeller seal (the one with a spring). I initially thought it belonged to the shaft but once I removed that piece the pump works like a charm. Really thanks for your quick reply and I really jumped the gun since my kid (and his friends) wanted to use the pool over the long weekend. Love this forum!!!!
    and found this out once I noticed the impeller actually started to spin then gets "stuck"....lessons learned and certainly learning alot this year as a first year owner...
    Jul 2009
    Houston, Texas
    9,377
    Great! Glad it was a simple fix. Enjoy your weekend!
    Love TFP? Become a
    TFP Supporter!
    hoskim's Avatar
    May 2016
    83
    Thanks again!
