Thread: Pump bonding questions
    Jun 2016
    Monterrey, Mexico
    34
    Question Pump bonding questions
    Hello guys, as some of you know I live in Mexico, so pool building codes are not clear
    I'm in the process of finishing my inground pool and now I need to know about bonding the pool pump to the bonding grid
    all of my equipment and electrical connections are In a closed cement machine room about 20 feet away from the closest inner wall of the pool
    I have already bonded the wet light niche to the rebar
    But my question is if I have to bond the transformer of the light and the pool pump to the bonding grid even though both are 20 feet away from the pool
    Being English my second language I get a bit confused about the NEC code
    Thank you for your help
    11'x21'x4.4'
    7.0K IG Concrete pool
    Hayward Swimpro 19" Sand Filter
    1HP pump
    Pentair Intellibrite 5G 500W equivalent white light
    Dec 2014
    Houston, Texas
    134
    Re: Pump bonding questions
    Article 680.26 details the bonding requirements for permanently installed swimming pools in order to “eliminate voltage gradients in the pool area as prescribed.” Bonding the metallic parts in and around the pool area prevents differences of potential from developing in the event of an electrical equipment fault and reduces the possibility of electric shock. The area created by bonding the metallic parts together is known as an equipotential plane.
    The NEC requires bonding all of the following metallic parts in a permanently installed swimming pool with a #8 AWG solid or larger conductor.
    Equipotential Bonding of Permanently Installed Swimming Pools
    • Concrete reinforcing steel and all metallic structural components. Uncoated reinforcing steel and all other metallic structures.
    • Underwater lighting. All metallic parts (housings and mounting brackets). This includes the transformers.
    • Metal fittings. Metal fittings for pipes, drains and water inlets.
    • Electrical equipment. All metal parts of any electrical equipment associated with the pool including pumps and recirculating equipment, heaters and blowers and automatic covers.
    • Metallic tubing and conduit, metal-sheathed cable, metal piping and all fixed metal parts.
    In addition to metal wiring methods and equipment, any component within 5’ horizontally and 12’ vertically from the water must be bonded.
    Info taken from Eritech at erico.com
    Jun 2016
    Monterrey, Mexico
    34
    I understand that as a YES
    Besides its only 20 feet of 8AWG wire from the rebar to the pump. Nothing to lose and safety to gain.
    11'x21'x4.4'
    1HP pump
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,778
    The idea of bonding the pump or heater has nothing to do with distance from the pool. They are electric devices directly connected to the pool and should be bonded to the pool regardless of distance.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Jun 2016
    Monterrey, Mexico
    34
    Thanks!
    11'x21'x4.4'
    1HP pump
