Thread: Clean water. Algae at the bottom
    Jun 2016
    Batavia
    30
    Hi, thanks to everyone here on the forums I brought my swamp pool to a crystal clear pool this summer. It's been great except for the fact that I keep getting alge on the bottom of the pool and on the walls. I vacuum and I keep my chlorine levels up with 3 inch chlorine tablets. I dont know how to stop this. The water is clear until i sweep or vacuum, then it has a green tint to it. The bottom looks like it has clumps of algae when this happens btw. Thanks.
    Above ground round pool 22' diameter 4' deep. 100gpm cartridge filter
    Jan 2012
    'burbs of Augusta, Georgia
    7,264
    Re: Clean water. Algae at the bottom
    With each and every puck you use it is adding both chlorine & cya to your water. As your cya level rises, so does the requirement to add more chlorine to compensate. SO it becomes quite a vicious cycle as the FC was enough when your cya was, say 40ppm, but inadequate now that your pucks raised your cya to 50ppm and this lets algae take hold.
    The only solution is to use chlorine that doesn't continue to raise your cya (hint: liquid chlorine, aka bleach) and possibly drain water to lower your cya level. But we need concrete test results to see where you are.
    Which test kit are you using? Can you provide us with:
    FC
    CC
    pH
    TA
    CH
    CYA
    we'll be able to advise you better when we know those values. Thanks!
    domct203's Avatar
    Jun 2015
    CT
    3,577
    Did you ever clear your water last month?
    Numbers all crazy. Milky water. Please help!
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Part of pool maintenance is to brush the sides of your pool each week. That along with keeping your water balance using TFP recommended levels will keep your pool in good shape.
    Divin Dave,
    Jun 2016
    Batavia
    30
    Yea I got my water clean finally and have been able to swim the past month or so. I have been keeping my water clear until this issue kinda crept up on me this week. I use the hydrotools test kit from the pool store.
    domct203's Avatar
    Jun 2015
    CT
    3,577
    Quote Originally Posted by Slyons81 View Post
    Can you please post a complete set of test results from your TF-50 (in the thread I linked to above, you said you have a TF-50). The hydrotools kit is an OTO based kit that does not check CYA.
    Please post:
    FC
    CC
    pH
    TA
    CH
    CYA
    You have algae because your FC level is/was too low for your CYA. You will need to SLAM the pool again.
    Dom - TFP Guide
