Thread: solving for volleyball net sleeves with centered spa?
    Jun 2016
    FL
    901
    We were hoping to add sleeves into our pool decking (travertine) for volleyball posts, but our spa will be centered on one side of the pool. Has anyone seen any creative ways to tie the net into the spa wall or work around the spa? It will only be up temporarily when playing, but we didnt want to have to get MacGyver creative to rig it up. Thoughts?
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    Re: solving for volleyball net sleeves with centered spa?
    Props for thinking ahead on this topic. Check out the link below. There is a picture for "Custom System over Spa". I'm sure they'd be happy to talk about it with you.
    https://www.coolpoolproducts.com/pages/gallery.html
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Jun 2016
    FL
    901
    Quote Originally Posted by bmoreswim View Post
    Thanks! this is perfect. Prices are reasonable for a custom professional setup. Hopefully same size as umbrella holders.
    Mar 2016
    McKinney, TX
    156
    We had a similar situation because we have a raised wall on the back of our pool. How deep is your water? Ours is 3.5 to 5 to 4 feet. One thing to keep in mind is that usually you want the bottom of the net to be as low as possible, close to the water level. With those set ups shown, the net is a foot or so higher than the deck, which is really high when you are in the pool trying to play near the net in 5 foot water. Our builder put a volleyball sleeve behind the wall but put a flush flat rope anchor on the pool wall under water so we could tie the bottom of the net so that the net could be lower. I will see if i can find a picture. If your pool is only 4 feet in the middle it might not be as much of an issue.
    Edited to add: Ours is like the picture on the cool pool products website titled "18 inch raised wall"--they used a wall anchor
    17K gallon, 18x40, 107 perimeter, 550 sq ft gunite inground pool with raised spa. 3.5 ft. - 5.0 ft. - 4.0 ft depth. Pentair equipment. DE filter. English Walnut travertine paver decking, lueders limestone coping. Wet Edge Primera Stone Sapphire Treasure plaster.
