Results 1 to 8 of 8
Thread: Dirt on bottom of pool
    Aug 2016
    Chapmansboro, Tn
    36
    Good morning all, my pool sets in back yard surrounded on 3 sides with trees.
    I get some dirt from wind, rain and so on. If I don't vacume pool within a couple of days
    bright green (algae?) will appear on some of the dirt streaks. Water is crystal clear.
    Vacume and all is good. Can I use an algaecide to stop this?
    FC 7
    CC 0
    PH 7.4
    TA 100
    CH ?
    CYA 41
    OCLT <.5
    Sorry, this should have been in algae section.
    Moderator note, JVTrain: moved to Algae- Prevention and Treatment
    Last edited by JVTrain; 09-02-2016 at 11:26 AM. Reason: Moved to Algae- Prevention and Treament
    New (Aug4th) AG, 8400gal, Ecokleer sand filter (45gpm max)
    1 1/2 hp Century ecokleer pump, Taylor K2006 kit
    Aug 2014
    Northern IL
    4,615
    Re: Dirt on bottom of pool
    Green stuff sounds like algae. Can you describe it in more detail?
    Aug 2016
    Chapmansboro, Tn
    36
    It's a bright green streak that sit's on top of the dirt that settles in the bottom of pool. No where else, but on the dirt. Thanks Bill
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,591
    Skip the algaecide and do a proper SLAM on your pool.
    Aug 2016
    Chapmansboro, Tn
    36
    Will do. Thanks Bill
    Aug 2016
    Chapmansboro, Tn
    36
    I just brought my pool to SLAM level of FC 16 by pool math. Do I keep it there just long enough to pass the 3 rules, and wait to see what happens when new dirt that falls to the bottom? Thanks Bill
    Before slam--
    FC-5
    CC-0
    PH-7.4
    TA-100
    CYA-42
    Apr 2010
    East Texas
    9,591
    Once you pass all 3 criteria, keeping your FC in the recommended range will help tremendously in deterring algae. Dirt isn't algae..........(but can pick up a stray traveler or two). If it was, my pool would be solid green due to some road work behind my house--tons of dirt hauling going on. Back to vacuum!
    Aug 2014
    Northern IL
    4,615
    I would personally go with a slam/shock level of 18. A CYA reading of 42 is more likely closer to 45 as the scale is logarithmic, not linear.
