Results 1 to 7 of 7
Thread: Cleaning SWG
    Jul 2016
    Wesley Chapel
    34
    Cleaning SWG
    Hi all,
    We had the pool refinished with pebble sheen. When I took the SWG out to clean I noticed there are little pebbles stuck inside the plates. I have tried forcing them out with a hose but they are stuck in there. SWG is working fine though. SHould I be concerned? Is there anything I can do to get them out? They aren't filled with them and flow seems fine but there are a handful stuck in there. I am wondering it they will damage the plates.
    Greg
    15' x 30', 13.5K Gallons, Pebble Sheen, 2 Deck Jets, Haywood 4820 DE Filter, Haywood Northstar 1.5 HP Pump, Haywood T-Cell-15, Haywood Heat Pump, Haywood Navigator Pool Vac
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: Cleaning SWG
    Try to gently nudge them out with something like a popsicle stick.
    Jul 2016
    Wesley Chapel
    34
    Re: Cleaning SWG
    Ok. I just don't want to damage the plates. I guess I'll go buy some popsicles.
    Jun 2011
    Long Beach, CA
    2,790
    Re: Cleaning SWG
    If they aren't long enough try chops sticks. You don't want to scrape the plates with anything metal as that can damage the coating on the plates.
    ITR's Avatar
    Nov 2014
    Clermont, FL
    320
    Re: Cleaning SWG
    Chinese and Popsicles for dessert. Now that's something I can get behind. I guess the question I have is how are they getting in there? Is your SWG put inline after the filter?
    15' x 29' 10,300 gal w/ spa, IG-Plaster (Stonescapes Tropics Blue), 2spd WhisperFlo pump (1.5hp WFDS-26), Pentair Clean and Clear CC200 cartridge filter, Pentair MasterTemp 300BTU heater, Clear o3, RS-8 iAqualink
    May 2016
    Phoenix, AZ
    171
    Re: Cleaning SWG
    Or a wooden paint stir stick. The SGS Breeze SWGs comes with one. Work great.
    13k Pebbletec Pool/Spa, Hayward Ecostar, SGS Breeze 540 SWG, Pentair C&C 420 cartridge, Pentair MasterTemp Heater, Caretaker system, TF-100 & Taylor K1766 test kits
    Jul 2016
    Wesley Chapel
    34
    Re: Cleaning SWG
    Well that is what worried me. Yes, the SWG is after the filter - it is the last piece of equipment water flows through before heading out to the returns - so I am not sure how they could make it all the way to the SWG. We had the filters grids changed when we had the pool refinished. (Haywood DE filter - 4820). Odd??
