Thread: How warm for IG vinyl liner replacement?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I know this is a bit of an odd question, but how warm does it need to be to replace the liner in an inground pool. I know many of the threads on this subject talk about liners being easier to handle after being warmed by the sun, etc. Well I have an indoor pool so don't have that luxury, and I would ideally like to change out the liner in the off winter season as it is showing its age and starting to wear through the print pattern in places on the floor (either this year or next). My current liner is about 12 or 13 years old, and the 2 liners before it were both changed out in the warmer months after catastrophic failures. (seam split open on one, ATV (Kawasaki Mule) ended up in the pool for the other.
    Ike
    p.s. I have a ducted 120,000 btu portable (ish) indirect fired diesel heater so I can heat the air up reasonably warm on demand, but at a cost of about 1 gallon per hour of diesel. (It will heat the air in the pool house air from near freezing to 70 degrees when it is 25 degrees outside in about an 1.5 hours) The pool house usually does double duty as a green house for freeze sensitive plants in the winter and I use said diesel heater to keep things warm when we have hard freezes (or for much of the winter a few years ago during the polar vortex mess), did not need it at all here last winter. My only concern about the heater is it has a safety thermostat that turns off the heat if the return air is over 86F, could probably trick it to heat the room warmer than 86 by bleeding in some cold air on the return though.
    May 2016
    Troy IL
    476
    Re: How warm for IG vinyl liner replacement?
    I can't answer this question, but I'm very curious how an ATV got in your indoor pool
    17,500 gallon IG Vinyl
    Pentair Tagelus TA60D Sand filter
    Pentair Challenger 1.5HP pump CFII N1 1.5A
    Taylor K-2006-A, Stenner 45MPHP10 auto chlorine feed
    Jan 2016
    Oklahoma
    69
    Quote Originally Posted by camueller View Post
    Me too.
    Vinyl, 20' X 44' in-ground, 35,000 gallons, Inteliflo VS 3HP, Triton TR-100 w/ activate, MasterTemp 400,000K LP, Dolphin Supreme M500, Hydramatic Hydraulic Auto Cover, TF-100 Test Kit.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    See Worst thing ever in your pool? also the lower left of this photo shows the scuff marks mentioned, doors to the right are where the Mule came in. Not actually the same doors anymore, those were replaced a couple of years back due to wood rot.
    May 2016
    Troy IL
    476
    oh that's right, I do recall that story. Crazy! Sounds like you do have a cool setup though.
    As to your original question, I'm by no means an expert, but I would think a new liner left in the upper 70's for a while would be limber enough to install. 80's even better. If it were me, and I got no other answers/advice, I'd probably just heat the place up with your system and let it maintain whatever temp it will get to overnight, and then the next day get to installing the liner.
    PoolguyinCT's Avatar
    Jul 2014
    Connecticut
    1,375
    60s ambient minimum - otherwise you are tugging and yanking on things you shouldn't. Keep in mind , most manufacturers will "fall or summer cut" material w/o mention.
