Thread: New pool motor running hot? Can't touch it for more than 5 seconds
    Sep 2016
    Houston
    1
    Recently had my pool motor replaced due to the old one getting fried due to lack of water circulating (had a guest drain the pool on accident). While the motor is on and working, motor seems to work fine but I can only put my hand on it for 5 seconds or less before it gets too hot. My pool guy says it's fine (he's the one that installed it) but the guy has made so many mistakes that I don't have any confidence in what he says.
    Pool Motor:
    Century - B855
    HP 2.0
    Volts 230
    amps SF 10.0
    rpm 3450
    frame Y56Y
    shaft 1/2 threads
    bearing ball brg
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,581
    Re: New pool motor running hot? Can't touch it for more than 5 seconds
    Welcome to the forum. Plenty of air circulation around it?
    Dec 2014
    Riverside California
    482
    Electric motors are not 100% efficient. Say the motor is drawing 2300 Watts (10 Amps x 230 Volts) and is 80% efficient, it would dissipate 460 Watts of energy as heat. A 2 horsepower motor running continuously will feel hot to the touch. Ambient air temperature will add to this heat also. So hands off!
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    I've notice if I touch the side of the pump facing the sun it's very hot. If I touch the shaded side, it wasn't.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Do you know the pump make and model# (not motor info)? The B855 is an up rated motor and if you have a 2 HP full rated pump, then it will overload the motor.
    Mark
