Results 1 to 10 of 10
Thread: Cloudy Pool and TFPC Not Working for me
    kountrygal's Avatar
    Aug 2016
    shreveport La
    6
    Moderator comment: 3 Threads merged together, it may seem a little disjointed at first
    Hello everyone, I'm Connie, here in Shreveport, La dealing with loads of rain. I'm a Newby pool owner 18k water size. Am so desperately trying to learn how to treat my pool. Had terrible green water/cleared that up but can't get it crystal clear???
    kountrygal's Avatar
    Aug 2016
    shreveport La
    6
    So far from what I've read I can see I need a pool test kits can someone recommend on the internet where I may buy one thank you
    kountrygal's Avatar
    Aug 2016
    shreveport La
    6
    Cloudy water "(
    I'm a pool newbie, 18kg/24ft round above ground.
    Got the green out but can't get past the cloudyness. Can someone recommend what kind of pool test kit I need to buy and where thank you so much
    kellyfair's Avatar
    Jun 2016
    Tampa, FL
    883
    Here's where I got mine:
    TFTestkits.net
    This one is great, enough chemicals for multiple tests.
    I became a supporter of TFP as well, and got a discount!
    Also, if you can put all the details of your pool in your signature (see mine) it will help people to help you. Lastly, you'll want to start a thread asking for help for your particular problem.
    16' by 4' Intex Ultra Frame AGP
    Intex 120V Krystal Clear Sand Filter Pump & Saltwater System CG-28679 with E.C.O.
    Hayward Through Wall Skimmer, Intex Auto Cleaner - works great!
    TF100 Kit and Speedstir
    Get the Pool School ebook, free on Google Play!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,471
    Welcome to TFP!
    I use the TF-100 from TFTestkits.net. it is the best value based on this, Pool School - Test Kits Compared
    kountrygal's Avatar
    Aug 2016
    shreveport La
    6
    Thanks so much..will make purchase.
    kountrygal's Avatar
    Aug 2016
    shreveport La
    6
    I'm so upset that I can't get the bbb to work for me I could cry! 24 round pool, water refuses to be clear. Just when I think I'm seeing progress I get in and it turns green as if all gunk is sitting in bottom being stirred up.
    Extremely frustrated.
    I.used 6 bags of walmart shock, 2 big boxes of soda and still nothing. I must have spent $100 in bleach just the past month.
    What does "cya" mean?
    jjwalker's Avatar
    S. Louisiana
    198
    hi kountrygal,
    sorry for the frustration, but, and pls,don't take this rudely (from one louisianian to another) if you don't know what cya is you can't possibly be following the BBB method. and you definitely would not be putting Walmart shock in your pool.
    I suggest you read pool school until you have a full understanding of what's going on...and don't be scared, it took me 2-3 times to fully understand, but once you do, it will be awesome. do you have a test kit? and if so, which one?
    edit: *full...my bad lol
    18x36 vinyl / sport pool 5.5' deep / 1.5hp Tri-Star 2spd / Hayward c3030 325 sqft cartridge / ~15k gal / TF100
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,318
    kountrygal, if you start a new thread and explain what you have been doing up to this point and
    where you are at now, help from others will be fast at hand.
    Dolphin E10 Cleaning Robot.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,805
    The good news is that there are some clear aspects of your approach that jump out to us. Which means that the rules of the science world have not been suspended for your pool and relief will be easily attainable so long as you have some POP left. That's Pool Owner Patience.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
