Results 1 to 15 of 15
Thread: Stupid Question of the Day
    Laenini's Avatar
    Aug 2008
    Brooklyn Center, MN
    90
    I was digging around in my garage today and came across a box that some of the pool parts had come in. Peering into it, I found a rectangle piece of plastic that is roughly the size of the skimmer opening. The plastic says "Hayward" on it and looks like it snaps right into the skimmer and maybe acts as some sort of flap over the opening. So, what is this flap for? When should I be using it? Should I even be using it at all? Maybe its purpose should be obvious to me, but I am afraid it isn't. Can anyone educate me on this?
    Leanne
    Pool: 24' round by 48" deep AGP
    Waterway 1HP-2 speed pump, H100 Heater, sand filter, skimmer, using BBB (love it!)
    Hot tub: 2008 CalSpas, 8x8, 8 seats, 60+ jets, ozonator
    3 step bromine sanitation
    Re: Stupid Question of the Day
    Do you have a picture? Sounds like it is a flap that prevents debris that has been drawn into your skimmer from escaping.
    25,000 gal IG Utopia pool/Raypack gas heater/BBB
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    It sounds like a weir, which is the flap that ideliver speaks of. Does it have a piece of styrofoam on the back of it?
    Weirs aid in the suction of the skimmer. Here's a post I made a while back inquiring about weirs; theres some really good explanations of what a weir is needed for.
    Weirs and tennis balls
    If it's big enough to fit over the faceplate of the skimmer, then it could be a cover that's used to close off the skimmer during the winter.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Laenini's Avatar
    Aug 2008
    Brooklyn Center, MN
    90
    Yep, its a weir I'm sure now! There is styrofoam attached to the backside of it and it isn't quite as tall as the skimmer opening, so it wouldn't be any type of winter closure I'm sure. I'm going to put it in tomorrow and see what it does. Thanks for the help! I learn so much from all of you!
    Leanne
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Always glad to help! Just FYI - the styrofoam faces in towards the skimmer. If it's like mine (two little pegs at the bottom of the weir fit into two holes in bottom front of the throat of the skimmer), it'll be easier to install from the pool side of the skimmer.
    Intex 8110 SWCG
    "Fear the Schnauz!"
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    900
    Quote Originally Posted by MikeInTN
    The weir actually allows the skimmer to work properly...it keeps the water flow regular, if I run skimmer without it, it sucks a lot of water into the skimmer and then the water flow stops...then the pump re primes and it sucks a lot more water into the skimmer...Kinda like a toilet flushing. With the weir in the water just flows into the skimmer at a steady rate and keeps the **** on the surface of the water flowing into the skimmer as well. It comes in handy for sure.
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    I just wanted to say Thank-You for this thread. The information I gained from it has made a difference in my pool.
    Some years ago I took the weir out because it was just such a hassle to deal with when hooking up the vacuum. After reading this thread and the one referenced in it about weirs and tennis balls I scrounged through the various pool boxes, retrieved the weirs and put it back in. What a difference it makes!
    Happy Father's Day to all you dads out there!
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    I hear you Anna. Several years back we replaced our skimmer faceplate with an "AquaDoor" for winterization, so I don't have to drain in the winter. But our old faceplate had the weir attaching to it. And the new one didn't. So we've been without a weir for 6 years now and it is definetly doesn't skim as well without one.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Ann, they make replacement weirs that are "spring loaded" and will 'retro' into a skimmer that doesn't have the holes to hold it. These guys will sometimes pop out on their own, but usually manage to stay in place
    Luv& Luk
    -Ted
    11,969
    Really? Where can I find?
    Mar 2007
    4,160
    I'll have to look into that - I've installed them before so know they exist, I was kind-O-hoping someone else would know
    Luv& Luk
    -Ted
    11,969
    You're such a tease. :P
    pool4me's Avatar
    Sep 2008
    Bucks County, PA
    124
    Quote Originally Posted by frustratedpoolmom
    I think these ones are all spring loaded. (Just happend to previously run across them online).
    http://www.poolcenter.com/parts_skimmer_weir.htm
    33'x15' x 52" Aqualeader
    Gallons ? - (I use appx 13,500 to calculate "stuff")
    33 x 15 x 4.3 x 5.9 = 12,558. or . . The Pool Calculator = 14,400
    Hayward S-166T 100Lb Sand Filter - Hayward Power-Flo LX 1HP Pump
    Intex S.W.G.
    11,969
    I'll have to check it out. Thanks!
    Clarksville TN
    17
    Oh great. I also saw this piece of plastic with the Styrofoam and was not sure if that was something to use when winterizing the pool (since the pool installers did not put it in) so I just kept it in the garage. But I will put it in now and see what the difference is. I did realize that some of the beetles in the skimmer will float back into the pool when I shut the pump off to clean the skimmer and backwash and such. So I guess this is to prevent this! I am so glad I read this! Thanks guys.
    Proud owner of a 24ft round above ground pool. Hayward Power Flo LX Pump 1.5HP with Dream Line Sand Filter. Since June 13,2009.
    ~Silke~
