Thread: Going from ColorLogic light to a Pentair Amerilite
    My ColorLogic Led light is dead and has to be replaced. The cost for a new ColorLogic was over $1,000. My pool service man said we could replace it with a Pentair Amerilite. Will that work? It is about 1/2 the cost.
    Thanks for your help!
    East TN
    13,000 gal San Juan Fiberglass Pool;SWG; GoldLine Pro Logic Controls
    Hayward Sand Filter; Hayward Max-Flo XL Pump;Polaris 380; Hayward ColorLogic LED
    Raypak Gas Heater
    Apr 2013
    Sacramento, CA
    2,769
    Re: Going from ColorLogic light to a Pentair Amerilite
    The cost for the Hayward Colorlogic is around $400. Tell him to reduce his installation cost. The Pentair is around $200. You need to be sure it will fit in your niche, but your pool guy should handle that.
    How old is the light. You may have a warranty claim with Hayward if you have other products you purchased at the same time.
    Note the Pentair warranty is only one year also.
    Thank you! I called Hayward for advice but was on hold for over 30 minutes. So, I emailed them and they said I would need a new light. It is about 6 years old.
    East TN
    Raypak Gas Heater
    Jan 2016
    Oklahoma
    69
    You might want to check out the Color Splash XG series made by J&J electronics. They have a 3 yr warranty. We have had ours in for about a month so no long term feedback, but we like them so far. http://jandjpoolspa.com/ColorSplashFixture.html I called them before I bought them and they said they are serviceable if you're familiar with electronics.
    BTW, I'm not associated with J&J, just have some in my pool.
    Vinyl, 20' X 44' in-ground, 35,000 gallons, Inteliflo VS 3HP, Triton TR-100 w/ activate, MasterTemp 400,000K LP, Dolphin Supreme M500, Hydramatic Hydraulic Auto Cover, TF-100 Test Kit.
