Results 1 to 8 of 8
Thread: Motor/pump just died, full pool, and Hermine on the way - HELP!
    Chairman Meow's Avatar
    Jun 2015
    Florida
    14
    Our pool pump/motor died on us a few days ago, we planned to put a new one in this weekend, but now we're getting tons of rain from Hermine and our pool is about to overflow! Other than using the bucket bailing method, is there a way to drain some of the water from the pool with a non-functioning pump?
    11K gal, IG plaster, screened in, circa 1982, Hayward CX800RE cartridge filter, 1HP Doheny pool pump, north-west exposure with partial morning shade and full afternoon sun, testing with TF100
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    Re: Motor/pump just died, full pool, and Hermine on the way - HELP!
    You can rent a pump from Home Depot. Check here for availability: Submersible Pump 2" Rental - The Home Depot
    To keep the pool from becoming a swamp you can add liquid chlorine and brush it around to mix it up.
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    Jun 2015
    Florida
    14
    Thank you!
    Yuma AZ
    71
    Ditto to what kcindc posted. You can also purchase an inexpensive Submersible Pump from harbor freight.
    10,000 gallons IG Freeform, 8ft raised spa,pebble finish
    FNS 60 Sqft DE Filter,2HP Whisperflow for Pool/Spa filtering
    2HP Whisperflow for Spa jets
    1HP Whisperflow for Waterfall
    Master Temp 400,000 Btu Heater
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    How to siphon using your vacuum hose
    Quote Originally Posted by madwil
    when I had a Intex, I used a standard vacuum head and hose, and set a syphon over the side instead of using the pump at all- as long as you don't mind watering the grass, and replacing water (same as vacuum to waste!)
    fill hose with water- start at one end, attach to vacuum to weight/hold underwater.
    push hose underwater along the length, so it fills entirely
    when you reach the other end, water should bubble out of it
    Hold both ends under water
    grab the middle of the hose, throw it over the side so a loop is hanging lower than the water level in the pool
    work back the length of the hose away from the vacuum head
    throw the end on the ground where you want the water to drain
    start to vacuum!
    when done, lift vacuum out of water to break suction, and drain to other end so gunk doesn't come back into pool
    Love TFP? Become a
    TFP Supporter!
    Aug 2014
    Northern IL
    4,615
    Use some type of hose to create a siphon.
    kellyfair's Avatar
    Jun 2016
    Tampa, FL
    1,155
    I own this little guy. Surprisingly effective and speedy for such a small pump. And Prime eligible!
    16' by 4' Intex Ultra Frame AGP
    Intex 120V Krystal Clear Sand Filter Pump & Saltwater System CG-28679 with E.C.O.
    Hayward Through Wall Skimmer, Intex Auto Cleaner - works great!
    TF100 Kit and Speedstir
    Get the Pool School ebook, free on Google Play!
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    Ace has great little submersible utility pumps.
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
