Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: Please help. Fractured Glass Tile. Need Opinions and Ideas.
    platipus's Avatar
    Feb 2015
    Houston, TX
    374
    I've been posting my pool build updates for a while now. It's been slow going for various reasons, but we're finally getting to the end. We've run into something though that I am not really sure how to address and am curious what the thoughts of the collective are. So here we go....
    A couple months ago I posted about the fact that a LOT of our clear/blue iridescent glass brick waterline tile was fracturing as shown here.
    At the time, when I psoted about it, BigEinAZ posted this article about it which seemed to explain everything. Poor quality Chinese import tile that was subject to thermal shock fracturing.
    http://www.aquatictechnology.com/edi...osaic_tile.htm
    We ended up having all the tile torn out and our builder found a replacement from one of their normal vendors here in Houston (NPT). We felt comfortable that with a brand like NPT, we were going to be OK. The original tile came from an online vendor who was not interested in doing anything except saying this was due to a lack of expansion joints at every possible point. Our builder, his mason and the article BigE posted seemed to point at something else which seemed much more plausible to me. This was a quality issue with the tile itself.
    The issue is that now the NPT tile is doing the exact same thing. The amount of fractured tiles are slowly progressing. We blue taped one whole area and the masons replaced those tiles and now there are fractured tiles again in that area again.
    NPT has evidently told our builder that "this happens" but that it doesn't effect the "quality of the tile" or cause it to fall off.
    Functionality aside, I'm curious what others would say here. It's kind of like getting a new car with dings all over it and hearing "yeah but it drives just fine". We chose glass tile because of the aesthetics. Now granted, you don't see the fractures if you are just looking at the pool from outside. If you stand in front of it and look, then it becomes evident.
    I can't imagine that this happens all the time or there would be 100 posts about "don't ever choose glass tile..."
    NPT also fails to mention this as a feature. "Sure it fractures, but that is part of the charm!" said no glass tile marketing material ever.
    So my two questions here are:
    Would anybody take this as-is to get the project complete and let it go? This is just what happens with glass tile and fractures are really not that big of a deal?
    Is this an installation problem as well that is compounding the amount of fractures? Is it made worse because the mason did "X" or failed to do "Y" ?
    Thanks
    plat.
    Modern Geometric-ish Social Pool (4'-5'-4') ~13' x 47'. Sun shelf. Perimeter overflow spa. RiverFlow Swimjet. Dog ramp. "Bubble Lounge"
    Link to my patio build, completed 2013
    Link to my pool build, Aug '15 - Sep '16
    platipus's Avatar
    Feb 2015
    Houston, TX
    374
    Re: Please help. Fractured Glass Tile. Need Opinions and Ideas.
    Deja Vu?
    http://www.troublefreepool.com/threa...le-is-cracking
    I was doing a search to see if I could find any other posts about this. SouthFL2016 posted this. I had to do a double take to make sure this was not one of my own pictures....
    plat.
    Jul 2016
    Niagara Falls, NY
    86
    I would not take it as is, I'd make a different tile choice. I'm not sure if the cracks go all the way thru the glass but if they don't I'd guess they eventually will and then they'd all have to be replaced anyway.
    Apr 2013
    Sacramento, CA
    2,769
    I havn't heard about this with light stream what do their instructions say?
    Aug 2014
    Houston tx
    2,524
    Plat, I would not accept it. I know you've had a long build but as gorgeous as your pool is, I think you'd regret not having the glass tiles replaced. How much of the tile is cracking?
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    twinkiesmommy2009's Avatar
    Aug 2015
    Cypress
    1,679
    I agree with the others. If this were "common" we'd have heard of more instances. It seems that both of these are the same color tile or quite close. I'm sorry you're dealing with this and I know you must be feeling done. I would select something different or this would bug me for the life of the pool in a big way.
    Started 5/31/16. 38'x23', 618 sqft., <14,000 gallons, 8' spa.Travertine coping. Raised beam w/3 sheers. Large sunshelf w/3 bubblers. SWG IC40, Pentair VSP, 520 cartridge, color LED lights, Easy-touch, screen logic, Maytronics S300i robot, and Wet Edge Prism Matrix finish (Deep Sea Blue with Indigo plaster). Build Thread: Another in Texas - Cypress Texas | MUD District | HOA Approval | Great Escapes Pools
    kellyfair's Avatar
    Jun 2016
    Tampa, FL
    1,082
    Your thread caught my eye because my daughter does stained, fused and mosaic glass work. I wondered when I saw the photos if temp fluctuations could cause this. Found this... interesting reading, especially the part about choosing opaque over clear.
    READ Consulting; Glass Pool Tiles Failure Analysis
    16' by 4' Intex Ultra Frame AGP
    Intex 120V Krystal Clear Sand Filter Pump & Saltwater System CG-28679 with E.C.O.
    Hayward Through Wall Skimmer, Intex Auto Cleaner - works great!
    TF100 Kit and Speedstir
    Get the Pool School ebook, free on Google Play!
    Aug 2014
    Northern IL
    4,615
    Nice link, Kelly!
    platipus's Avatar
    Feb 2015
    Houston, TX
    374
    Kelly, thanks for that link. What I read from that is essentially, true clear glass tile is its own risk factor because of infrared light passage and the resultant heat loading and also no clear glass tile has been able to pass thermal stress test certification. Neat.
    The NPT tiles do not seem to be fracturing as bad as the Mineral Tiles ones were, but they also have not been up for as long as the MT ones either. The thing is both my wife and I really really like the clear tile look.
    This is also meshes with a bit of the reaction from NPT when our builder asked them about it. One of the first questions was if it was clear tile....
    What we are hearing is that functionally, this is not a problem. Aesthetically, we have a decision to make. Do we stay with the clear tile and live with some fracturing, as long as it is not going to impact any functionality, or select a different tile (and we looked at literally 100's of tile options before we arrived as this choice).
    In all honesty, when you look at the expanse of the tile, the fractures do not jump out at you. It's when the sun is direct into the face of them and you are standing there looking at them specifically. If there is any shade on them or from a side angle, they go iridescent and it's almost impossible to see.
    So for right now, at 11:16 am. On a Friday. We are leaning towards living with it if we can get a warranty commitment that if they do actually fail (break out) or get significantly worse in some way (actually chip) that we are covered. We need to mull this over a bit.
    This is one of the pitfalls of having a very specific design vision I guess. If we were even a little marginal on loving the look of these they would be coming out....
    Thanks all.
    plat
    kellyfair's Avatar
    Jun 2016
    Tampa, FL
    1,082
    If it were me, I think I'd keep them. I have stained glass that has fractured like that and it hasn't changed the beauty or function of the piece. Granted, I'm not dealing with water. But, I just don't see those pieces shifting to allow water in behind them.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,818
    Here's a quicky...that annoying clump of grout on the left side of the picture bothers me 10 times more than the cracked tile. I can see where the charm of it would increase over time. Though I can see initially being put off by it. I'm more of a natural guy and appreciate how things weather over time, assuming again that it has no effect on functionality. As the volume of cracked tiles increases, which presumably it will, the effect will become more balanced and less obvious.
    I have certainly seen numerous glass tile cracking threads over the years. And far fewer about regular tile. I liken it to plants (which I often do). Would I rather have a plant that needs constant attention because it's needy/not sited well, or one that is native or at least thrives in my micro-climate?
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    platipus's Avatar
    Feb 2015
    Houston, TX
    374
    Quote Originally Posted by bmoreswim View Post
    LOL at that clump. Pictures taken before cleanup. I don't have any doubts the builder and mason will have all of that kind of stuff cleaned up.
    UPDATE:
    I spoke with one of the main guys at NPT. Basically, they said they stand behind their product and that they don't think this will affect functionality of the tile (i.e. it won't fail and start to break out). If I want it swapped out though, they will work it out with our builder and change us out to another tile selection. He also said that knowing the issue now, if we decide to keep the tile, they will note it (and I said if we agree we'd want this in writing) and if 5 years down the road or whatever if we had a true failure situation, that they would also work with us then. So kudos to NPT. This is not the experience or response we got from Mineral Tiles....
    Thanks
    plat.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,818
    That is good to hear (and get in writing).
    TortugaCat's Avatar
    May 2016
    Boston, MA
    82
    What about trying the same color tile in a smaller format, like 1x1? Perhaps it would be less likely to fracture?
    Pool + Spa in MA -- 40' x 16' gunite pool, 8' x 8' spa with spillover. PebbleSheen Ocean Blue. Vibrance Glass Nero 2" x 2" tile. SWG, Paramount in-floor cleaning system, 400 BTU Sta-Rite LP Gas Heater, ACT1500 Heat Pump, S7M120 Sta-Rite Modular Media Filter, IntelliPro XF 3.0 HP Pump, SuperMAX VS 2.2 HP Pump, AquaLink automation. LP gas firepit. 1700 sf stamped concrete patio.
    Sep 2015
    Atlantic Beach, FL
    70
    I've been fusing glass for more than 20 years and had considered making my own pool tiles. After some research, I decided against it, but I have the article below bookmarked. The article is a few years old, but knowing the nature of glass, there may not yet be any definitive answers.
    Special Report : Glass Tile| Pool Spa News | Tile, Best Practices, Codes and Standards, Building Technology, Joints, Salvaged Materials, Installation, Recycling, American National Standards Institute, Tile Council of North America
    8K gal 13'Wx19'L IG kidney. 3.5' to 5'6" depth. Pentair: Ultratemp 120 heater/chiller; Intelliflo 2 VS pump; Intellichlor IC40 SWG; cartridge filter; EasyTouch controller. 3 wall returns, 1 skimmer, 1 cleaner line. Tremron Oak Run coping and pavers. Noble Tile Toscano waterline. Marbletite's Freestone pebble in St. Thomas. TF100 and K1766 test kits.
    platipus's Avatar
    Feb 2015
    Houston, TX
    374
    Quote Originally Posted by TortugaCat View Post
    We did actually look at square tile options. Ultimately it still came down to the aesthetics. We liked the look of the rectangular offset pattern. It reflects a repeating design element in the entire pool/patio (Spa tile, patio floor tile, deck travertine, fireplace stone tile face, etc...) It's a bummer that it become an issue, but I think we're good with the trade-off given the situation as long as the guarantees are solid.
    Quote Originally Posted by Plazaglass View Post
    Could you even imagine something that custom? Well, I mean obviously "you" can Plaza because you work with glass and thought about it, but for the rest of us....
    Thanks
    plat.
    Sep 2015
    Atlantic Beach, FL
    70
    Quote Originally Posted by platipus View Post
    plat.
    Just for fun (and off-topic), here are some I made that I thought we might use on the edges of the steps, but I think we'll be able to see the steps without markers. These are about one square inch. Sorry for the lousy iPhone photo
    PoolguyinCT's Avatar
    Jul 2014
    Connecticut
    1,379
    Several of my friends are quoted in that article & it merely scratches the surface(no pun intended)
    I have Lightstreams and probably 30-40% of the tile is cracked. Do I like it? No. But I have learned to live with it.
    40 x 11.5 rectangular pool 3.5 - 8 ft, 8x8 raised spa with 12 jets, travertine coping, Wet Edge primera stone, Lightstreams tile, SWG, Caretaker infloor system, Coverstar autocover, EasyTouch, VS3050, 2 whisperflo, Pentair 420 C&C cartridge filter, heater and solar.
  20. Back To Top    #20
    platipus's Avatar
    Feb 2015
    Houston, TX
    374
    Just WOW!!!!! Out of curiosity, from a production cost perspective, what would the price be per sq/ft for something like that?
    Quote Originally Posted by sdpool View Post
    Bummer to hear that. This is beginning to sound in some ways as the plight of the glass tile pool/spa owner. Also I feel privileged to have started a thread that got your first post after 5 years!!!!
    plat.
