Thread: Adding Borax
    Aug 2015
    Grandy, NC
    135
    Adding Borax
    First time this summer, needing to bump up pH. Instead of trying to dissolve borax in bucket of pool water (unless warm pool water now will dissolve it better) to add in front of return, would the cya sock method work better?
    19300 gal, AG vinyl, 1 HP Pentair Dynamo two stage pump, 5 yr old Hayward Vari-Flo sand filter, pool 14 yrs old, well water, testing with Taylor K2006
    Jul 2016
    Philly Suburbs
    27
    Re: Adding Borax
    You could just sprinkle it lightly while walking around the pool (2 or 3 laps per box). It should dissolve fine.
    22,500 gallon in ground pool with vinyl liner. DE filter. Taylor K-2006.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Adding Borax
    More here on adding chems, Pool School - Recommended Pool Chemicals
    VinDeeLoo's Avatar
    Jun 2016
    Tonkawa/Oklahoma
    204
    Re: Adding Borax
    Why not aerate? Do you need to raise TA too?
    VinDeeLoo
    7600 gallons ~ AG ~ Summer Waves Cartridge C Filter ~ using pump that came with our Summer Waves 18 x 48 pool ~ Taylor K-2006 (SpeedStir & Sample Sizer) ~ no well water or water restrictions
