Thread: Where does those small air bubbles come from?
    Dec 2015
    San Jose, CA
    31
    Hello
    I just completed a SLAM, the water is back to clean now. When I brush the pool everyday, I find there are many small air bubbles on the vinyl under water (not foaming actually, but like the air bubbles when you put Coke in the glass, but they are much smaller). Where do they come from? Anything I should worry about?
    Last test result:
    FC: 39 (just stopped adding more 10% liquid sodium hypochlorine)
    CC: ~0
    PH: N/A (but before SLAM, it was 7.4)
    TA: 70
    Cal Hardness: 100
    CYA: 100
    Thanks!
    10,200Gals, 10X34, 3'-4'4'' deep, rectangle in-ground vinyl pool; Solar cover;
    3/4HP Advantage pump; CC150 Pentair cartridge filter;
    NC22 SmartPool Smart-Kleen robot; and a 2-wheel PoolCleaner of HAYWARD
    Tailor K2006 test toolkit;
    Jan 2012
    'burbs of Augusta, Georgia
    7,264
    Re: Where does those small air bubbles come from?
    Are these bubbles near your returns? Do you have a SWG?
    Dec 2015
    San Jose, CA
    31
    I don't have a SWG, and these bubbles are not near my returns either, but just spread out on the interior wall randomly.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    As the chlorine killed the algae during your slam, there was a lot of outgassing from the algae being oxidized This is the most probable cause of the bubbles. Its nothing to worry about.
    Once you get your pool properly balanced when the slam is done, particularly the FC and pH, and you brush the pool walls, the bubbles will subside.
    hope this helps,
    Divin Dave,
    Dec 2015
    San Jose, CA
    31
    Thanks, Divin. It does look like what you said, now, about 1 week after slam, everything is fine and the air bubbles gone.
